7th Jun 2021, 4:33 pm | #21 |
Re: Odd gm readings when testing valves. Maybe 42 isn't the answer to this one?
I'm not sure the term 'super valve' is appropriate. I suspect they're on the way to being crappy thyratrons.
7th Jun 2021, 4:41 pm | #22 |
7th Jun 2021, 4:56 pm | #23 |
Where did you get the test figures for the TH233?
These are the AVO test which uses AC: Triode Va=100, Vg=-2, Ia=4mA Hexode Va=150, Vs=100, Vg=-2, Ia=2.6mA The Mullard HSVT which tests under DC conditions: Triode Va=98.81, Vg=-5.31, Ia=2.5mA minimum, typical 5mA Hexode Va=98.65, Vs=100.04, Vg=-3.04, Ia=3.35mA minimum, typical 6.7mA The AVO uses AC for testing and the figures are what to expect from an AVO and may not match the valve specification, http://www.r-type.org/pdfs/th2321.pdf. The HSVT uses DC so should reflect the specification. The figures here are created from my emulator as the instrument only shows red/amber/green. |
8th Jun 2021, 6:32 am | #24 |
I've had this too with 807's and other OP valves, the odd one tests way over spec for emission but responds as per normal.
Andy.
