11th Nov 2020, 10:33 pm | #21 |
Re: First project (mini mod)
Hi Barry, You can get an illuminated magnifier on a sort of angle-poise mount for between £25 - £30 that would really help. I am seriously thinking about getting one myself since even with reading glasses on I am struggling with stripboard soldering. Just google it - seem to be available from several sources. Cheers, Jerry
12th Nov 2020, 7:28 pm | #22 |
The OP should make sure the fet Q1 has the gds in the right holes. I'd recommend the BF256 rather than the original 2N3819. But they have different pin outs! Beware!!
Good luck. Ian |
12th Nov 2020, 8:51 pm | #23 |
Is this a good idea making my own circuit board so that I can see to solder. Do i carry on or do i give it up as a bad job? My plan is to cut out where it needs to be after I have soldered it together and placed hot glue between the wires to stop them shorting. Am I mad or what?
Thanks Barry |
12th Nov 2020, 9:42 pm | #24 | |
Your parallel wires idea is similar in some ways. It's worth a try, although it has drawbacks. One is that it will be tricky to solder an integrated circuit into all that. The other one is to do with the stability of a radio frequency circuit laid out like that. But it looks like you are on the exciting first steps of a path... So there is nothing to lose by trying and seeing what happens! It's much preferable to you walking away from it! Keep us posted, there's plenty of support here!
Al Last edited by Al (astral highway); 12th Nov 2020 at 9:48 pm. |
12th Nov 2020, 10:48 pm | #25 | |
But to make things easier, try and get hold of a bit of printed circuit board - single sided will be all you need, but double sided is just as good in this case. Google images of "electronics ugly construction" and you can see what can be achieved, especially if you also cut some small 5mm x 5mm-ish bits of copper board and super glue them down as needed. This is often called Manhattan construction. But all I do is use single-sided copper board and use a PCB layout to wire the components underneath and the copper surface as the ground plane and negative, with countersunk holes though the top for leads to pass through. Photo of top of board attached. I can't find one of the underneath, but just imagine printed copper tracks replaced by wires. |
12th Nov 2020, 11:22 pm | #26 |
I wrote up this alternative to a PCB technique in September 1995 HRT magazine. Unfortunately that issue is missing from worldradiohistory.com/
So if anyone has a copy... |
13th Nov 2020, 12:43 am | #27 |
Very neat build indeed. I would have been interested in your write up. I use Manhattan style construction all the time, it’s great.
I wonder though if the OP is needing to keep things simple and clear for the time being. It’s great to have a challenge and there’s also a line which feels enough but not overwhelming. I hope Barry can find that line
Al |
15th Nov 2020, 11:55 am | #28 |
Hello, got all the components on apart from L1 and L2. L1 number 2 pin has to be stretched out and put in the hole next to it. Then in between 3 and 4 there is a pin comes out but I do not know what number this goes to, is it the actual metal surround pin? For L2 the number 2 pin seems to go in between the circuits and the wire coming from 1 and 6 where has this come from?
Tried to explain this as best as i can. Hope I have not confused you. Thanks Barry |
16th Nov 2020, 9:05 pm | #29 |
Don't laugh as you look at my effort but still struggling to find where the pins go on L1 and L2. As soon as I get them in I can try it. Very much doubt it will work first time but you never know. Thanks Barry
17th Nov 2020, 12:14 pm | #30 |
Barry, pin 2 on L2 isn't used, so I think you could drill a larger hole for it on the board between the two tracks, neither of which appear to be used also. The link between 1 and 6 appears to be connecting L2's metal case to earth - there's a similar link on L1 between 3 and 4. You'll need to make a link to pin2 on L1, as your drawing shows.
Bryan |
19th Nov 2020, 9:44 pm | #31 |
Hello it works in a fashion. I only get it to play through the radio when I am touching the round thing i have marked in the picture with the pen. Any ideas? When I touch the wire where the aerial is there is nothing at all. Thanks Barry
20th Nov 2020, 10:22 am | #32 | |
When you turn the centre ferrite slug of L2 (just use a flattened cocktail stick as it will break with anything metallic) the signal should increase in volume in the radio. If not there is something wrong around Q2 and associated components. Obvious question, but is Q2 in the right way? What voltage readings have you made? The RF might affect your meter, but assuming you're using a 9V battery, you should be getting something like this: Q2C 4V Q2B 0V Q2E 0V IC1 pin 5, 4.5V If you're getting some modulated signal I expect you have correct voltages around Q1 and the IC. L1 sets the frequency and L2 matches the output transistor to that frequency. If they are not both tuned to the same frequency you'll get hardly any output. I find it hard to get my head around Veroboard layouts, that's why I use any of the other construction methods previously mentioned in this thread. Check again that all the tracks you think are cut really are, with no shavings shorted to adjacent tracks. Let us know how you get on. Ian |
20th Nov 2020, 11:16 pm | #33 |
Tried it again today and it worked for about 20seconds. then it has died completely. Can I have blown anything by any of the tracks touching. Can't see any but if it had would it have blown anything? Thanks barry
20th Nov 2020, 11:17 pm | #34 |
Hey Barry, congrats for getting some response out after your first attempt! I’m just dropping by to say that as Ian has covered all the bases...
Al |
21st Nov 2020, 10:20 am | #35 | |
Ian |
21st Nov 2020, 4:16 pm | #36 |
Just found the instructions I supplied with the MiniMods I sold.
It might be useful to post them here. Ian |
22nd Nov 2020, 12:27 am | #37 | ||
Sorry I really new to all this. thank you for your patience. |
22nd Nov 2020, 11:25 am | #38 |
Q2C at 4.9V is a good sign, suggesting the voltage at the output of IC1 is about half the supply voltage.
You can't measure the actual value of most components in situ because other components and semiconductor junctions around them will change the apparent values. For example R1 won't measure 100k because that has D1 and part of Q1 across it which are also likely to cause it to measure differently depending on the polarity of your meter leads. However, R7 should measure 100R as long as you have nothing connected to the L/R input. R7 is isolated from any resistive effects of IC1 by C12, so 21R means something is wrong. IC1 pin five is pin 5 of the LM386 chip. Just look up the LM386 data sheet, but the image is here In case you haven't found the circuit diagram of the MiniMod it's in the original article link below. Remember I changed Q1 to a BF256 which has different pinout to the original 2N3819. Other than very carefully checking the values of each component - by lifting on end if necessary to remove it from the effect of other components - I'm not sure what else to suggest, except you posting a list of voltage measurements from the negative battery terminal to all the active device terminals. Unfortunately during this lock down, I'm not in Fakenham where my workshop is and I don't have a MiniMod to hand to exactly compare voltages, but I should be able to suggest what's wrong from your list of voltage measurements. Ian |
24th Nov 2020, 12:32 am | #39 |
Hello quick question Inductors L1 and L2 are both 90 µH but mine are 90 uol are they the same thanks
24th Nov 2020, 10:23 am | #40 |
Yes, L1 and L2 are the same. They are about 90 microhenries with the core approximately flat with the top, but they are adjustable by turning the core with a wedge-cut cocktail stick. The value applies to the main winding - the one with the three pins with the centre pin being the tapping. The other winding is for coupling and not used in the L1 position.
Don't know what you mean when you say yours are "90 uol" unless you mean that's what they are marked. Here is the link to Spectrum Communication's page with all the data for their inductors. See the section "SPECTRUM 10mm RF/IF COILS" SPECTRUM 10mm RF/IF COILS The pinouts, 1, 2, 3 are the main winding. Pinout 3, 4 are the coupling winding. The table gives the resistance of each winding: 1-2 57R; 2-3 19R, 1-3 76R (57+19) and 4-6 5R. (There is no pin 5.) Ian |
