Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets and Parts Wanted (private buyers only, no swaps)
Sets and Parts Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 20th Mar 2024, 12:31 am   #1
Alan Bain
Default HP BNC connector
I'm looking for an HP 1250-0870 BNC panel mounting socket. It mounts in a D shaped cutout in the panel and is intended for direct attachment of a coax.
(An elephant seems to have sat on one on an HP frequency source and rendered it elliptical. I thought I had some suitable replacements, but they mount in a much smaller hole)
Various sources exist - but I don't like the sound of ones that suggest they were pulled from nice pieces of HP test equipment!
Alan
Alan Bain is offline
Old 20th Mar 2024, 12:41 am   #2
Julesomega
Julesomega's Avatar
Default Re: HP BNC connector
That looks like a thin coax cable like RG188 or RG174, in which case I have two possible candidates. Let me know the critical mounting dimensions.
Name:	BNC RG174 Jack.jpg
ID:	295129   Click image for larger version
Name:	BNC Bulkead Jack.jpg
- Julian
It's good here
Julesomega is offline
Old 20th Mar 2024, 11:45 am   #3
Alan Bain
The mounting hole cutout looks like this. Dimensions are marked but since handwriting on a mouse pad can be hard to read it is essentially a truncated 12.73mm diameter hole with distance from flat to edge at 11.90mm (I am sure this was originally in inches!)
Name:	DSC_6663 (Large).jpg
Old 20th Mar 2024, 1:55 pm   #4
Julesomega
Julesomega's Avatar
Your internal dimensions are 0.1mm larger than the connector external dim's! I'll pop one in the post if you PM or email me your address. The screen connection has to be crimped, so leave that til last and crimp lightly with pincers or large pliers. The centre pin is soldered, you can see the capillary feed hole on the similar RG58 type on uk.rs-online.com
Unfortunately their datasheet omits any assembly instructions so you will have to work out the cutting lengths by careful experiment.
- Julian
It's good here
Old 20th Mar 2024, 2:21 pm   #5
Actually, it looks just like the one I'm holding in my hand
1250-0870 50 Ohm short-thread BNC on one end, about 2 ft thin 50 Ohm coax and a 50 Ohm SMB on t'other end. Yup, it's actually marked 1250-0870 on the connector
And it even has the tiny EMC toroid on it.
It was something I kept as a spare when I put the gated sweep measurement hardware in my 859x prototype analyser. So, completely surplus to requirements.
Radio Wrangler is offline
Old 23rd Mar 2024, 7:47 pm   #6
Alan Bain
Thanks for a couple of very kind offers of assistance above. I took up David's offer and the socket with lead arrived today. As might be expected since it is the identical part number to the damaged one, it fits perfectly.
Moderators, this thread can now be closed.
Old 23rd Mar 2024, 11:06 pm   #7
All's well that ends well, and Julian's pristine new BNC remains should he need it for something afresh.
