21st Jul 2022, 1:47 pm | #1 |
Pye Transistor MW+2SW Set
I have just pulled this out of the shed and it's silent.
I have had it since the 1980s and it used to work well. Looks like a possible candidate for Tin whiskers. It has no ID plate. If someone can identify it please then I will look for schematics before starting to repair. |
22nd Jul 2022, 8:40 am | #2 |
Re: Pye Transistor MW+2SW Set
My Colleague Alan Bednall designed this Export-Only Model in the mid-1960s. The input /output socketry was comprehensive and is a seldom seen feature. I'm sorry, I don't recall the model number.
Edward. |
22nd Jul 2022, 9:46 am | #3 |
Looks like a close relative of this one:
https://www.radiomuseum.org/r/pye_unknown_am.html Though that's not much help! It's probably an export set (from the MW, 2SW band coverage) so data might be elusive. A search on the transistor lineup might suggest a similar UK model (LW, MW, SW perhaps) which could help with a "near enough" circuit.
23rd Jul 2022, 9:45 am | #4 |
Thanks both for your replies. That is the one. Interesting that it was intended for export.
It turned up at the church bazaar in Comberton near Cambridge around 1986 and I have had it ever since. It seemed to work well. I will look out for a similar set for a schematic or otherwise fix it from first principles. I have haven't yet worked out how it comes to bits. |
23rd Jul 2022, 10:13 am | #5 |
Given that you found it in Cambridge, it may have 'escaped' from the factory or been sold off to staff.
