28th Nov 2007, 7:51 pm | #1 |
1939 Detrola Model 282 Pee-Wee Portable Radio
In October, I bought this prewar portable because of the unique dual 45-volt HT battery it used. Only a couple of manufacturers made batteries for this set, and production ceased a few years after the war. As a result, all of these sets have sat silent for over 60 years.
Earlier, I found pictures of a pristine 282, its original Detrola-brand batteries intact, and I asked the new owner to scan copies of them. Shortly after that, I built up a pair of replica batteries. The LT battery was a standard 742-style common to the era, and my replica runs on one to four C cells in parallel. The HT battery was more of a challenge. It's a 90 volt package split into 45 volt halves. Once I completed the box, I figured the easiest way to distribute the load would be to assemble two sets of five PP3's and stack them one on top of the other. There's nothing unique electronically with the Detrola 282--it's one of many portables built around the then-new 1.5 volt battery tubes. This particular chassis was untouched, still sporting its 1939-style G series tubes. All paper caps were replaced along with the electrolytic. I switched it on--and was greeted by Silent Sam. Zilch. To my surprise, every &$^#%@ tube--was blown. So, for the first time in a VERY long time, I had to rummage through my stash and find a new set of tubes. Most of them are the shorter GT types, but because of the shield styling, the 1A7 had to use the tall G type. Fortunately I had one. Second switch-on, the radio sprang to life. Speaker is a little strangled due to an off-center cone, but otherwise it plays and has average sensitivity.
Just playing with high voltage.... |
28th Nov 2007, 8:53 pm | #2 | |
Re: 1939 Detrola Model 282 Pee-Wee Portable Radio
Hello Bill
Very nice, I like that one! Did you have to do much cleaning to the cloth covered case, it looks to be in a good condition? The batteries are first class as well Quote:
I'd have been surprised too! I've never (so far) found a set with all the valves blown. Looks like someone at sometime has been careless with the LT supply! |
29th Nov 2007, 9:40 am | #3 |
More fantastic work Bill! The speaker looks quite modern in the photograph, is it less obvious in the flesh?
I wonder if someone has tried connecting up various power supplies to get it to work and blown the valves. Regards, Keith |
29th Nov 2007, 2:45 pm | #4 | ||||
29th Nov 2007, 6:23 pm | #5 |
Hi Batterymaker
Curiously I though the speaker looked a modern type with a metallic speech-coil cover! If it is the original then usually the magnet can be removed and the coil cleaned if there is grit or rust, a tiny amount of WD or Servisol does no harm, and then re-centering the magnet as it is put back on. Some early speakers have a flat spacer that can make putting the magnet back on a bit more tricky as it has to be held central while tightening the main magnet body. Geof |
