30th Jan 2010, 2:19 pm | #1 |
Precision Wiring
Back in the '40s & '50s my father was an electronics enthusiast and built various items including radios, a tape recorder, a television and a radiogram. I think others who heard about these projects sometimes thought they would have a go themselves. My father would then be called to fix such newly completed sets when they didn't work! He once mentioned that some of these amateur builders went to great lengths to ensure that all wires were straight and all bends were perfect right angles. They thought the circuit would not work properly if the wires between components were a bit too long, curved etc. I wondered if forum members have seen old valve chassis wired up with this precision wiring?
30th Jan 2010, 2:54 pm | #2 |
Re: Precision Wiring
I had to do this when I went through the RN Electrical School - HMS Collingwood. Part of the course was to build an oscilloscope timebase and an AM Transmitter, both had to be wired as neatly as possible, all valve and built on aluminium chassis. Radio and TV sets were made to a price so I suppose neatness was not given such high consideration. The vast range of equipment I came across in the service was always neatly wired and some of the commercial test equipment too.
30th Jan 2010, 3:10 pm | #3 |
One only has to look at the wiring in early Leak, Quad and Radford equipment to see that these and other manufacturers went to the trouble of making their products as neat as possible.
30th Jan 2010, 4:25 pm | #4 |
It is interesting to note that many of the early EMI sets had laced wiring looms as well as untidy point-to-point wiring - I suppose that a pre-formed loom helped prevent wiring errors so saved money in the long run. Although the wiring on these early sets could be a bit untidy, they were marvellous compared to the early 1950s Philips sets, especially their TVs.
Cheers Brian |
30th Jan 2010, 5:46 pm | #5 |
Personally, I really appreciate neat wiring and logical layout. I remember the first time I looked inside a Sony stereo cassette - shock about covers it, and this was using a PCB. How could such an untidy mess work so well? I've never bought Sony since... sorry in advance to any Sony lovers...
Of course, neatness doesn't guarantee practicality, but it sure looks good. It may also be the case that many amateurs built their 1930s and 1940s sets by carefully following Mr. Camm's wiring diagrams, rather than the schematics. If so, it isn't hard to see how errors could have crept in. -Tony |
30th Jan 2010, 6:20 pm | #6 |
I read somewhere that ex-Services people brought up on neat wiring can sometimes come a cropper the first time they try to build RF stuff, as the neat wiring can have excessive strays. Neat is OK for DC and audio (although even there you have to careful about grounding) but messy can be better for RF!
30th Jan 2010, 6:33 pm | #7 |
I'm not sure I would agree with that.
One can build for RF, even VHF, and still have a neat layout. It may not, probably would not, have all rigid wire and right-angle corners, but should be logical and not look like a birds nest. |
30th Jan 2010, 6:57 pm | #8 |
I agree with Alan. Neatness still counts, and particularly in the RF world. Perhaps not according to the rules above, there is still a level of quality control.
Jim Mac |
30th Jan 2010, 7:56 pm | #9 |
Hi
I built a little superhet radio earlier this month, and it was a right old mess under the chassis, but it worked supprisingly well, I decided to tidy up the mass of dangling components and wires onto some small bits of pcb, and when I'd finished the damn thing didn't work anymore!! I still haven't got round to sorting it out.. regards, lloyd. |
30th Jan 2010, 8:02 pm | #10 |
I generally go for neat, regimented component layouts and wiring, but I am acutely aware of layout issues, strays, ground loops having spent a lot of time with switch-mode power supplies. Reconciling the two is not at all easy.
There's nothing worse than demonstrating a piece of equipment to someone, nonchalantly saying, "Of course, I designed it and built it myself," and for them to say, "Yes it looks like it!" |
30th Jan 2010, 8:02 pm | #11 |
In my apprenticeship at Thorn EMI I was taught to do neat wiring looms, all laced up with the proper cord. However, that was something of an anachronism in 1990!
In a modern parallel to the neat/scruffy RF wiring issue, a fair amount of today's PCBs are deliberately auto-routed with the tracks randomly crisscrossing each other. It helps to ensure that the various high-speed signals on a data bus, for example, don't all radiate in the same direction. Though the total emissions are the same, they're spread out nicely and thus don't create a problem when it comes to EMC testing. If they were all neat and tidy and parallel, the performance would be much worse. Chriis |
30th Jan 2010, 11:05 pm | #12 |
Any ex GPO apprentices ( actually we were "Trainee Technician Apprentices") will remember learning how to wire relay sets, with precision right angled bends / terminate cables on junction boxes /join u/g cables neatly or run internal cable in straight, neat lines .
And on an installation, getting a visit from the TECH 1 to get the wiring ripped out if it wasn't to his satisfaction . |
31st Jan 2010, 12:02 am | #13 | |
Yes I have done that a few times. With production manufacture neat wiring that works is a big plus to repeatable Quality with the end product. Mike |
31st Jan 2010, 12:14 am | #14 |
Not quite in electronics but when i was serving my appretiship an an industrial electrition i worked on re wireing controle pannels for large machenes mostely in the printing industery it was the norm to make the looms up with nice 90 degre bends and once finished all laced properly.
Jay
The light at the end of the tunnel is probably the headlight of an oncoming train |
31st Jan 2010, 12:45 am | #15 |
How about this?
https://www.vintage-radio.net/forum/...32&postcount=7 Or for thereally fanatic, this (PSU in 4th picture): https://www.vintage-radio.net/forum/...29&postcount=1 |
31st Jan 2010, 2:49 am | #16 |
Neatness does make fault finding easier and of course it LOOKS nice! But of course if you build it all neat and tidy and it doesn't work, not only is it heart breaking, it's annoying having to cut off the string and start checking!
31st Jan 2010, 11:16 am | #17 | |
"Oh yes I love television, all those wiggly lines"! |
31st Jan 2010, 11:39 am | #18 |
I served my apprenticeship in wiring and assembly and instrument making at the Marconi Company. Some of the cableforms where very complexe and marker sleeves where put on every wire and cable, and various crimped plugs and sockets had to be fitted.Trying to get a Cannon plug to go together after fitting all the wires was not the easiest task. Of course very high freqency wiring had to be point to point by the shortest route.
Geof |
31st Jan 2010, 12:47 pm | #19 |
Sometimes, beauty is only skin deep. The majority of my working life was spent as an engineer in the broadcast television installation industry. The installations consisted mainly of rack-mounted kit in 45U (1U = 1.75") high equipment cabinets, rows and rows of them. Behind the rear doors, the cables were always formed into looms and tightly laced or, later, tywrapped. Cables in the looms were all parallel and seemed, magically, to come out of the loom in the correct place and on the correct side of the loom - wonderful!
However, lifting a few floor tiles explains how it is done. The chaos under the floor enables the beauty above. The moral is don't lift the floor unless absolutely necessary! What Tin said about neatness helping fault finding is true if the circuit info is available. If not, lacing etc. makes tracing the circuit a nightmare. Cheers Brian |
31st Jan 2010, 3:21 pm | #20 | |
The boards looked fabulous, each termination from the loom bent at a precise right angle at TTL pin. The problem with this regime was fault finding. Although the PCBs looked brilliant, they never worked straight from production. We of course had circuit diagrams, but if the wire didn't go to where it was supposed to, it was a nightmare to find out where it was actually going to and an even worse nightmare to correct multiple wiring problems without ruining the look of everything ! A colleague of mine resorted to cutting all the looming and wiring point-to-point to get the PCB working. The whole thing ended up looking like red spaghetti with TTL buried underneath it. He then dumped it back to production to re-loom. We nearly had a walkout on our hands I have to admit to my own wiring being "functional" rather than "precision". My efforts always end up looking a tad "organic". We used to have a saying where I used to work that the mental stability of the engineer was inversely proportional to the neatness of the wiring. This is because we had some rather odd fellows who used to produce "mechanical" looking prototype circuits. The other saying was "it either works, or it fits in the box". I've found this to be particularly true in the past when trying to neaten Microprocessor based circuits working at lots of MHz. The point has now been reached where wired prototyping is now impractical for a large array of applications because of speed / crosstalk issues and also because of the use of fine-line IC's and also BGAs.
Chris |
