9th Feb 2021, 10:40 pm | #1 |
DDS Xtal Replacement
Hi all,
Can anyone point me at a kit ideally, or a working design for a DDS synthesiser to replace HF xtals in a transceiver please. I only need one freq initially, so VCO circuitry isn't required. I have spotted VK5TM's design but was hoping something was available a bit closer to home... Many thanks, Martin G4NCE |
9th Feb 2021, 11:26 pm | #2 |
Re: DDS Xtal Replacement
https://www.qrp-labs.com/ has similar in the form of 'ProgRock', look in the menu on the left of page.
You will have to send Hans an email though as I keep getting a 'Server down' message for the ProgRock page. |
9th Feb 2021, 11:52 pm | #3 |
Thanks Terry. Small world eh?! I have sent Hans an email.
Cheers, Martin |
10th Feb 2021, 12:22 am | #4 |
Hi also the vfo kit both kits require a lo pass filter to get sign wave out, I have built sevral of his kits they work well Mick
10th Feb 2021, 1:11 am | #5 |
Don't forget the 6V6 Electronics DDS 0-40MHz VFO Short Kit for AD9850. I built one and it does exactly as stated
- Julian It's good here |
10th Feb 2021, 4:27 am | #6 | |
And less places to hide
I would recommend checking drive levels though. |
10th Feb 2021, 4:45 am | #7 |
The DDS output gives quantisation distortion and a stepped approximation to a sinewave.
If you use a different look up table to get a squarewave approximation, you get jitter. Making a sinewave, lowpass filtering below Nyquist and only then using a comparator to create a square wave (if that's what you want) performs as an analogue interpolator, fixing a fair amount of the quantisation distortion and doing interpolation for you. So all DDS require an output filter (lowpass or bandpass) or else you take a hit on spectral purity. David
10th Feb 2021, 2:45 pm | #8 | |
11th Feb 2021, 11:19 am | #9 |
Thanks all. Think I need to open the radio I was looking at generating the LO digitally for and get on the air (a Decca Messenger) instead of just working from the service manual, to see how much space there is inside. TBH the LPF does look a little on the overkill size at 10W to help replace a xtal... Although a boxed external variable source with an LCD does now sound an attractive, and more versatile, option.
Noted re the 3.3V/5v oscs. Martin G4NCE |
