Old 1st Jun 2020, 2:23 pm   #1
knobtwiddler
Default Removing Awkward Screw...
I need to open an enclosure. However, one of the screws on the base plate (flat, sheet steel) is cross-threaded into a brass stand-off underneath (which goes into a PCB, with nyloc nut on top). When I try and unscrew the M3 Hex-head screw, the stand-off simply spins around inside the PCB, along with the nyloc on top. This means that the plate is effectively bolted to the PCB, thus preventing access to the enclosure as the PCB can only be removed (and the nyloc accessed) once the base plate is off...
My options (as far as I can see) are:
i) Get a Dremel and try and slice off the cap of the M3 screw. This will risk damaging the base plate, so not ideal - but I'm not exactly spoilt for options. I'm not sure I'll be able to get the Dremel cutter in-between the screw and base plate.
ii) Try and drill off the head of the screw. Start with an extremely sharp 0.5mm bit and go up, in the smallest increments possible. The drawbacks to this method are: firstly, it'll need clamping in a pillar drill (a whole chunk of delicate electronics). Secondly, the head will need gripping with fine nippers to prevent it spinning.
If anyone here has a tip, I'd be extremely grateful. The screw is stainless, which is an added complication.
Thanks in advance!
knobtwiddler is offline
Old 1st Jun 2020, 2:28 pm   #2
Scimitar
Scimitar's Avatar
Default Re: Removing Awkward Screw...
Grind off the head with a Dremel SpeedClic grinding wheel.
Scimitar is online now
Old 1st Jun 2020, 2:34 pm   #3
Stainless can be a right begger to drill expect broken bits.
If using a dremel, grind the head off the screw. Go slowly and you should be able to save the panel. Protect things nearby from sparks and metal dust.
A new spacer would be easier than freeing the stub of the screw.
Radio Wrangler is offline
Old 1st Jun 2020, 3:24 pm   #4
Jon_G4MDC
Jon_G4MDC's Avatar
Is the screw countersunk or pan head?
Doh read it again! Hex head. I'm with David then. Grind it but it will get hot so the plastic won't like it.
Jon_G4MDC is offline
Old 1st Jun 2020, 3:36 pm   #5
The Philpott
The Philpott's Avatar
Wot he said, ^^^
SS does not grind well and most of the energy goes to creating heat- it may be seen to turn blue just before it gets too hot!
Dave
The Philpott is offline
Old 1st Jun 2020, 3:50 pm   #6
vidjoman
Is there any way to get access to the nyloc nut? Could it be jammed with a screwdriver or even a loop of plain wire around it and pulled tight enough to remove the nut as you turn the screw. Just a thought.
vidjoman is online now
Old 1st Jun 2020, 4:23 pm   #7
emeritus
Axminster Tools used to do packs of second hand reground tungsten carbide small drills and burrs with 1/8" shanks, but they were't in their range last time I looked. They cope with stainless steel (and titanium). They were the only drills I found that would enlarge the holes in a stainless steel watch strap to take a larger size of watch bar.
emeritus is offline
Old 1st Jun 2020, 5:27 pm   #8
BRASSBITS
pictures of the enclosure will help
BRASSBITS is offline
Old 1st Jun 2020, 7:18 pm   #9
knobtwiddler
Thanks, all - much appreciated.
There isn't much to see. It is a 300mm x 300mm sheet of powder coated steel. The cap-head screw is flush against it. The brass spacer is on the other side, in a dense nest of circuitry, which cannot be disassembled without removing said screw, thus creating a chicken and egg situation in that regard.
Maybe a Dremel disk, but instead of trying to cut the head off, damaging the enclosure due to the.flush nature, I could attack it vertically, milling an x into it??
Old 1st Jun 2020, 7:30 pm   #10
David G4EBT
David G4EBT's Avatar
A tungsten carbide burr might do the trick.
I have a set for use with my Dremel and have found them very useful.
Better on stainless steel that HSS bits in my experience.
There's a set here which might have one or two in a suitable profile that might suffice:
https://www.ebay.co.uk/i/31287593895...b5054c5b135a6a
Hope that might help.
Every success in your efforts.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 1st Jun 2020, 7:44 pm   #11
60 oldjohn
I wonder if it had Loctite applied as anti tamper. If you use a left hand drill bit it may unscrew as it heats up.
John.
My favourite text message "I'll be there in five minutes, if not read again"
60 oldjohn is online now
Old 1st Jun 2020, 7:51 pm   #12
peterpiper
Have you tried freezer spray? .Heat the surrounding area with a soldering iron first then spray the screw head.
Peter
peterpiper is offline
Old 1st Jun 2020, 9:19 pm   #13
ronbryan
I suggest you clamp the chassis in a pillar drill, prevent the screw rotating with a slim BA style spanner on the hex head and use a carefully centred 3mm carbide 4 flute end mill to make a hole in the screw head the size of the bolt core diameter until it breaks off. Cool the end mill with a little paraffin on a small paint brush.
Ron
ronbryan is offline
