8th Jan 2016, 3:01 pm | #21 |
Re: Delta-S Soviet Sinclair Spectrum clone
The pics I posted in post 17 are with the scopes ground connected to a good ground point on the computers PCB. the pics I posted in post 18 are with the scopes ground connected to the video ground. I will see if I can dig out my other scope probe and see if it makes any difference.
Jay
The light at the end of the tunnel is probably the headlight of an oncoming train |
8th Jan 2016, 3:12 pm | #22 |
just a thought, probably wrong I hasten to add.... I wonder if none of the pins on the din socket are ground, and they might have used the case of the din plug as the ground ? I wonder if you checked with a dvm on resistance range to see which pins were connected to the ground point on the computer. I can't remember which early computer ( cpm based one ? ) I had to make up a lead to go between the monitor and the computer, it did use din plugs, and they did use the shield on the din plugs as a separate ground connection. regards Peter B |
8th Jan 2016, 8:11 pm | #23 |
It looks to me as though that last batch of measurements was made with the scope input mode set to AC - if not, then with a X10 probe with its compensation setting out of adjustment.
Were the most recent measurements with the probe on X1 and with the scope input mode set to DC? If not, can you try it again that way? |
8th Jan 2016, 10:24 pm | #24 |
all measurements taken have been with a X1 probe (has no X10 function) and all taken with the scope set to DC.
Jay
9th Jan 2016, 12:18 am | #25 |
I cant find my other scope probe at the moment but have tested this one has continuity and although the ground looks good from crock clip to BNC outer the probe itself measures 169 ohm from probe tip to BNC inner. Is this normal? or is my probe goosed and that's why I'm getting the readings I am.
Jay
9th Jan 2016, 11:34 am | #26 |
Hi, I think the scope probe should work ok with the 169 resistance from probe tip to inner bnc connection.
But I wonder if there might be a broken ground connection on the din socket on the computer itself ? [ or even on the scart cable you made up. there may be more than one ground connection required to different pins on the scart ? ] nice to see a picture of the computer on youtube ! regards Peter B |
