26th Jun 2020, 5:54 pm | #1 |
Removing curly cord from receiver
I have a red 782 phone. There's a significant 'rustle' and crackling sound, all of which seems to emanate from the inch or two of the curly cord immediately before it goes into the mouthpiece end of the receiver. One option would, I suppose, be to remove the curly cord, trim the individual wires by a couple of inches and then replace it; from past experience, however, knowing how filament-thin those wires are, just replacing the whole cord seems a better bet. Either way, I know how to remove the wires from the phone end, but can anyone tell me how to safely remove them from the handset? - There appears to be a clip holding the curly-cord in place, but I can't quite see how you're supposed to remove or replace it.
Other than that, any particular thoughts on where to get another red curly cord, or just Google it and see what turns up? |
26th Jun 2020, 6:46 pm | #2 |
Re: Removing curly cord from receiver
Dredging the memory from 50 years ago....
The crimped-on clip on the cord has two "ears". They will match two cutouts in the handset if you rotate the clip through about 45 degrees. Can't remember if CW or CCW. When the clip lines up with the cutouts, pull, and the cord should come out quite easily (the flexibility in the cord allows the rotation, best tool is a pair of "81s"
John G4FDD G-QRP 431 |
26th Jun 2020, 7:16 pm | #3 |
27th Jun 2020, 2:24 pm | #4 |
Thank you for your replies. I understand the principle now, although I'm having trouble finding a pair of pliers ( or any other tool for that matter! ) that will grip the crimped clip tightly enough to turn it without damaging it or it's surroundings. I'm not familiar with the term '81s', which makes me think I probably don't have any ...! If anyone has any suggestions for workaround methods of turning the clip, that would be great, otherwise I'll keep improvising till I come up with something.
Other than that, I'm having trouble finding a replacement curly-cord with the hard-wired u-shaped spade connectors at each end and the right amount of cores ( i.e. four ). Doesn't seem to be too much of a problem if you're in the USA, but so far I haven't come up with any in the UK. Given the fact that they seem pretty hard to come by in the first place, I'm not sure what the chances will be of finding a red one! Any thoughts on either of the above would be appreciated. |
27th Jun 2020, 2:32 pm | #5 |
I've always used long-nosed pliers but admit that it's not easy. As for a replacement, e-Bay is full of them or you could try: https://www.britphone.net/gpo-700-se...cables-2-c.asp
27th Jun 2020, 2:55 pm | #6 | |
Been known as 'Pliers Wiring No 2' since the 1930's and described as 'Pliers taper nosed 5 1/2 inch long, insulated'. But the term '81s' has survive. They come up from time to time on eBay particularly in exGPO toolkits and you can still buy new ones Every engineer had a pair. Last edited by Pellseinydd; 27th Jun 2020 at 3:09 pm. |
27th Jun 2020, 3:02 pm | #7 | |
The name 81s has stuck, at least amongst the older hands, and it is often recognised in BT, Royal Mail engineering, Royal Signals, and other government-related outfits. A bit like the Masons' handshake, I think !
27th Jun 2020, 3:32 pm | #8 |
27th Jun 2020, 7:55 pm | #9 |
Apparatus Terminating 1= AT1= 81
28th Jun 2020, 12:56 pm | #10 |
My old mentor told me that "81s" were distinct from "pliers wiring" as 81's had a cutting blade in the middle and were favoured on jumperframes as you only needed one tool . 81's could cut the jumper wire , strip it and terminate. However, as said, pliers wiring took over and all long nosed pliers from then on took the name 81's, with the mini version(designed to be used on PCB)getting the nickname ( in my area and possibly others)as 41's
28th Jun 2020, 3:23 pm | #11 |
Mine (ex Father in Law) are 81s then, having both cut and strip. My original ones got lost years ago. Neither were insulated or carried a makers name.
Curly cords: https://www.ebay.co.uk/itm/706-746-7...EAAOSwU~FWEEuk |
28th Jun 2020, 6:24 pm | #12 | |
To say "Apparatus Terminating 1= AT1= 81 " is the reason for the Pliers No 2 being called 81's makes a mockery of the Forum! No truth whatsoever in the statement !! I worked (when I first started with the GPO) with engineers who had worked with the GPO since the days of WW1 and had used the term '81's' when they were 'Tools Instrument No 81'. |
28th Jun 2020, 11:06 pm | #13 |
No truth whatsoever in the statement !! My. What a reaction! This is what I was told back in 1968 by an old T.O. Never doubted him. Why am I making a mockery of this Forum? Last edited by Euros1951; 28th Jun 2020 at 11:19 pm. |
29th Jun 2020, 1:24 am | #14 |
A little harsh perhaps, but we're all entitled to personal opinions.
An extremely wide variety of subjects are covered on these forums, and we believe and trust that all posts are made in good faith. That's the best anyone can do. As the original questions posed by the OP have been answered, this seems a good point to close the thread. |
