2nd May 2020, 10:26 am | #1 |
N2128H1T telephone
This 700-style telephone arrived this morning via eBay. I've not seen one like it before so I hope somebody can give me a clue as to its likely origin and purpose. There is wire mesh fitted in the bell gongs and under the board, so perhaps a tropicalised unit ? I won't be attempting to rewire or convert it, just a clean and polish.
2nd May 2020, 10:27 am | #2 |
Re: N2128H1T telephone
More pictures.
2nd May 2020, 10:33 am | #3 |
Very nice, and unusual to find a 2-transistor "magneto" ring generator as opposed to a hand-cranked one.
ETL = Ericsson Telephones Limited. The N...... number is also typical of Ericsson phones. Is the case a standard 706-type one, or is it bigger to accommodate that huge transformer and the two transistors? As usual, Bob Freshwater has the answer: https://www.britishtelephones.com/ericsson/n2128.htm This suggests that it was a late-1960s phone designed for old "CB" (etc.) systems which were likely to be modernised into "auto" systems. The phone could then be converted rather than replaced. Nick. Last edited by Nickthedentist; 2nd May 2020 at 10:41 am. |
2nd May 2020, 11:25 am | #4 | |
This telephone is just a basic magneto telephone for use on circuits where a magneto telephone was used. I have several of them acquired over the years. Not a rare item. Ideal for a 'point to point' intercom. |
2nd May 2020, 11:29 am | #5 |
Thanks Nick, I'll pore over the Freshwater Files! Two more pictures in the meantime. The transistor block lifted out quite easily. The case is a regular 706 type, as far as I can tell.
2nd May 2020, 11:38 am | #6 |
Thanks for the info/correction, Ian.
And yes, Sparks' pics in post 5 clearly show the socket for the reversible regulator found in the 706 etc., but permanently shunted by Cs and Rs soldered to its tags. |
2nd May 2020, 12:44 pm | #7 |
Thankyou both for the information. I don't have any use planned for the phone so it will be merely decorative once I've rebuilt and polished it. It came with a handset bracket to allow wall-mounting so that might be its destination.
2nd May 2020, 1:09 pm | #8 |
Nice find!
Ineresting ringer generator, anybody who knows if it actually gives AC between 25 and 25 hZ witch would be OK for most magneto telephones?? dsk |
2nd May 2020, 7:25 pm | #9 |
Looks better for a polish, even if it isn't functionable on a normal phone line. I just need to find two bolts to hold it together - hopefully some at home somewhere.
2nd May 2020, 9:45 pm | #10 |
Anyone know what is the reason for R2 in the ringing generator circuit (22ohms)
Thanks. |
