14th Nov 2018, 12:55 pm | #1 |
Does Virgin Media support pulse dialling?
Hi Guys,
I've recently recovered and also inherited a couple of nice Ercofon's - which I'd like to use occasionally. They are both rotary dial K14 seven contact 'International' Swedish built units that were converted some time ago for U.K. use [with BT flex and wall jacks etc.]. These units certainly worked on a BT system up until around the mid 2000's - but don't seem to facilitate dialling-out via my current Virgin Media [fibre] arrangements. Googled enquiries re. Virgin Media support of pulse dialling seems to have generated several seemingly 'evasive' responses from VM on various forums and threads - so my query is "what actually is the truth?" Another query is: What is the REN number for these particular units? And: can this be lowered by up-rating a resistance/by how much/which one? Thanks all ...... in anticipation!
Red to red, black to black. Throw the switch and stand well back! |
14th Nov 2018, 2:10 pm | #2 |
Re: Does Virgin Media support pulse dialling?
Pulse dialling from my 746 certainly works on Virgin here, but I can't help wondering if it depends on how old the exchange equipment is?
14th Nov 2018, 3:50 pm | #3 |
I don't have a pulse dialling phone to hand at the moment but pulse dialling worked OK here last time I tried it a few months ago.
Alan G6PUB, BVWS |
14th Nov 2018, 5:02 pm | #4 |
I have no personal experience of this, but has oft been said here that even where loop-disconnect dialling is supported by modern exchange equipment, the frequency and mark/space ratio may need to be within quite tight limits.
14th Nov 2018, 5:07 pm | #5 |
We are on Virgin Media and used a converted Trimphone for a few years in the sitting room.
I hope this helps. |
14th Nov 2018, 5:50 pm | #6 |
Our two 706s work fine on Virgin Media via their coax/fibre system.
Peter |
14th Nov 2018, 9:14 pm | #7 |
Lowering REN by inserting resistance is a myth. Bell motors are largely inductive and adding series resistance does little.
14th Nov 2018, 9:37 pm | #8 |
My understanding is that because Virgin as an amalgamation of former small local companies it depends on the equipment those former companies installed. LD certainly works fine in the former Yorkshire Cable area. I had heard that it didn't work in the North-East but OldTechFan96's post seems to dis-prove that.
I expect Dave to be right in that the equipment does work but has a much lower fault tolerance than in the days when dials were the norm. |
14th Nov 2018, 9:50 pm | #9 |
Hi, Pulse dialling does work (to a point) on Virgin Media POTS lines, however as has already been mentioned it does depend on the legacy switch (exchange) that a particular area uses.
Here on Teesside VM use a Nortel DMS100 switch which can be somewhat unforgiving of incorrect dial speeds. I believe this is due to that fact that the DMS100 is of an American design and expects a different make/break ratio of dial pulses compared to a Switch such as System X or System Y, which I guess have better tolerance of differences in dial speeds. Regards Andrew |
16th Nov 2018, 4:11 pm | #10 | |
The telephone bell that has served us for long has been extremely well designed. It is robust and simple and almost indestructable. It can be overloaded without damage. Fifty, sixty, seventy and eighty-year-old movements will still work as well as on the day they were manufactured. I don’t know about the design specifications, but I do know that an electromagnet will dissipate most power when the resistance is the same as the inductive reactance, i.e: the phase angle is 45° and the modulus is at its maximum. But yes... Adding a resistor just causes even less current to flow, causing nearly half the ringing voltage to be dropped across it. I tend to leave them out. I believe REN is referenced to a more modern 59D 4000 Ohm d.c. bell, typically 7186 + j8275. To quote from the European Telecom Standard ETS 300 001: 'Instead, these parameters are defined in terms of the concept of the "ringer equivalent number" or REN of the TE; this is a measure of the numbers of items of equipment that can be connected in parallel, the reference for a REN = 1 being a simulated ringing detector circuit consisting of an inductor of 55 H in series with a resistor of 7 kohms.' Which fits in nicely with the spec of the 59D bell-movement.
Regds, Russell W. B. G4YLI. |
16th Nov 2018, 5:09 pm | #11 |
This won't be as eloquent as Russell's post, but I'm sure many of us have found when a mechanical bell appears to be taking more of its share of the available current, the cure is to put a resistor in series with the offending bell and empirically adjust its value for the highest resistance that is consistent with the bell ringing reliably.
Maybe a plumbing analogy is called for? How about balancing central heating radiators using the lockshied valves? (Sorry no j notation).
-- Graham. G3ZVT Last edited by Graham G3ZVT; 16th Nov 2018 at 5:29 pm. |
16th Nov 2018, 5:41 pm | #12 | |
What? Outrageous!
16th Nov 2018, 6:53 pm | #13 |
Thanks chaps ..... I knew you'd have the answers! I've just serviced one unit .... and it performs perfectly - but doesn't seem to like being on an extension ......
