Old 11th Nov 2018, 9:50 pm   #1
dbrb222
Default 56C ringer.
Hi.
I have a 56C ringer, of the two screws that connect the power, one has vanished.
On the assumption that it does not magically reappear, does anyone know the thread? It seems to be an imperial thread somewhere roughly equivalent to M4.
dbrb222 is offline
Old 14th Nov 2018, 11:20 am   #2
Neil1970
Default Re: 56C ringer.
It might be a 3BA which is 4.1mm o/d or a 4BA which is 3.6mm o/d. If it's 3.6mm o/d you should be able to tap out to M4 or if it's 4.1mm o/d you might be able to tap out to M5 if it comes to it.
Neil1970 is offline
Old 14th Nov 2018, 11:47 am   #3
Dave Moll
Dave Moll's Avatar
More likely to be 3BA, as the GPO tended to use odd-numbered BA threads.
Dave Moll is online now
Old 16th Nov 2018, 11:51 pm   #4
dbrb222
Thanks - I've ordered £3.00 worth of 3BA from ebay - I'll confirm on here if they fit!
dbrb222 is offline
