Old 24th Jul 2022, 6:37 pm   #1
Michael Maurice
Michael Maurice's Avatar
Default AGA black and white TV
I have been asked to repair this TV which the owner imported from Sweden.
It was dead, having gone bang when the new owner plugged it in.
The fault was the paper wax capacitors across the mains!
Having replaced them I found a Rifa cap in the line 0/P stage that had cracked. When I replaced it I was rewarded with a raster with field problems. (See picture)
The frame stage comprises of a PCF84 and a PCL85.
I have replaced the cathode bias capacitor in the frame O/P stage, but time prevented me from going further.
What might cause this fault?
ID:	261451   Click image for larger version
ID:	261452   Click image for larger version
ID:	261453   Click image for larger version
Forum Moderator
Michael Maurice is offline
Old 24th Jul 2022, 7:04 pm   #2
Maarten
Default Re: AGA black and white TV
It could be a Swedish Philips chassis, I'm not sure which one or whether that's really the case, but you might be able to verify it by looking for labels and numbers on the chassis or the PCB (also in the copper pattern). That way it might be somewhat easier to find a schematic.
Maarten is offline
Old 24th Jul 2022, 8:27 pm   #3
1955APREN
1955APREN's Avatar
Faults like this are often due to faulty components in the cathode of the PCL85, you say you have replaced the by pass cap but what about the cathode
resistor has it gone low normally about 270R?
The set does have a Philips look about it. One Philips set had a frame output transformer that had a feed back winding that would go OC causing a fault like yours.
Regards, Derrick.
1955APREN is online now
Old 24th Jul 2022, 9:27 pm   #4
Michael Maurice
I checked the cathode resistor, it's a 390R but it went slightly high.
Forum Moderator
Old 25th Jul 2022, 4:35 am   #5
its ur aerial
its ur aerial's Avatar
Looks very much a Philips to me too, cramping at the bottom is normally
always associated with a fault in the Cathode circuit.
what's the voltage on the cathode ?
May be worth investigating Derrick`s suggestion, if the cap and resistor are OK.
Ken, G6HZG.
Life is not Hollywood, life is Cricklewood.
its ur aerial is offline
Old 25th Jul 2022, 10:29 am   #6
Welsh Anorak
Welsh Anorak's Avatar
What a strange looking TV! Is it AGA as in the stove manufacturers?
Could you hazard a guess as to the date - perhaps the CRT type will help.
Hopefully the fault shouldn't take too long to track down - the CRT looks good.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 25th Jul 2022, 12:01 pm   #7
Maarten
It would have been made around 1960-1965. It's the same AGA as the stove manufacturer. They actually made their electronics themselves and/or bought in from various manufacturers but at some point in time they seem to have switched to Philips made sets. I don't know whether Philips bought the rights to their name or they remained an indepedent trading company.
It would be relatively easy to confirm or reject the Phlips origin of the chassis.
Maarten is offline
Old 25th Jul 2022, 10:15 pm   #8
Richard_FM
Richard_FM's Avatar
Interesting to see, I wasn't sure if there was a Swedish manufacturer who made their own chassis rather than just make sets around imported major components.
Hello IT: Have you Tried Turning It Off & On Again?
Richard_FM is offline
Old 26th Jul 2022, 9:28 pm   #9
Maarten
Luxor certainly made their own chassis.
Maarten is offline
Old 27th Jul 2022, 12:17 pm   #10
German Dalek
German Dalek's Avatar
I have the same set, and parted 1-2 of them out.
In Sweden these models are called "tombstone" because of their style.
Do you want the schematic?
Regards,
German Dalek
And now something completly different:
MARC BOLAN, he was/is the real king of Pop Music!
German Dalek is offline
Old 1st Aug 2022, 11:14 pm   #11
Michael Maurice
Originally Posted by German Dalek View Post
Regards,
German Dalek
I’ve got the set back in the workshop and I’ve got the diagram. I’ll be away for a couple of weeks and will start on it when I get back.
Forum Moderator
Old 14th Aug 2022, 10:20 am   #12
Michael Maurice
I've done more work on this set. I've replaced a number of RIFA type capacitors and I found a 1M resistor in the height circuit that had gone high. When I replaced it, I had full scan. Except I have flyback lines at the top of the screen.
i get quite a bright raster with lines, should I not get snow!
The set at first seemed like it was VHF/UHF but there is no UHF tuner fitted.
Did Swedish TV operate on 625 lines at VHF? There is no system switch and it's certainly not 405 line!
As the set has a live chassis, I can't create a video input. What can I use as a converter?
Forum Moderator
Old 14th Aug 2022, 11:49 am   #13
Lloyd 1985
Lloyd 1985's Avatar
Have you got one of those multi standard modulators available? I have one and you can just feed in a signal from a freeview box or DVD player (anything that can output a 625 line signal really!) and then select what channel to output it on, and also set the sound frequency too. Have a look for ‘M69L RF Modulator AV-RF TV Converter UHF VHF Frequency PAL NTSC Standard’ in the usual places. I have successfully used one on an American Motorola 7” TV, in fact that’s what I bought it for, picture and sound were very good, and it didn’t mind having 625 lines fed to it!
Regards
Lloyd
Lloyd 1985 is offline
Old 14th Aug 2022, 1:13 pm   #14
Michael Maurice
Hi Lloyd,
Where did you get yours from?
Forum Moderator
Old 14th Aug 2022, 1:51 pm   #15
Lloyd 1985
Lloyd 1985's Avatar
Got mine off eBay a couple of years ago, they are available on Amazon and Aliexpress too. There is a version that accepts a hdmi input too!
Regards
Lloyd
Old 14th Aug 2022, 6:23 pm   #16
winston_1
Originally Posted by Michael Maurice View Post
I get quite a bright raster with lines, should I not get snow!
I would expect snow.
Sweden use 625 lines system B at VHF. Later UHF system G was used as well.
Note also their mains was 220v so you will be overloading it on our 240v.
winston_1 is offline
Old 14th Aug 2022, 11:16 pm   #17
Michael Maurice
There is snow, very faint snow, you can see it by turning the contrast up, the brightness down a bit and changing channels. It does have a 240V setting so I'll make sure its set for that.
Forum Moderator
Old 28th Aug 2022, 9:12 pm   #18
Michael Maurice
We have a picture and sound! The height doesn't go high enough and there are flyback lines on the top of the picture. I will post diagrams soon.
Forum Moderator
Old 28th Aug 2022, 9:43 pm   #19
roffe
It's called AGA Mobil 4346.
Lots of AGA TV:s here:
https://www.aga-museum.nl/aga-televisie/
roffe is offline
Old 28th Aug 2022, 10:26 pm   #20
Michael Maurice
Here is a scanned circuit of the line and frame timebases
Forum Moderator
