11th Jun 2022, 6:59 pm | #21 |
Re: Magneto phone generates no ring voltage
Joe, I'll be disappointed if you and your mates didn't have SCR-536 handie talkies like "The Terrible Ten"
-- Graham. G3ZVT |
12th Jun 2022, 5:57 am | #22 |
I took the magneto assembly apart. Here are some pics. I'm unsure of the correct names for the various parts.
12th Jun 2022, 6:16 am | #23 |
One can put a NE2 bulb between the wires of f the generator and it should light if there is voltage. IIRC they strike between 60v and 90V. I have used old military field phone gennys to light the bulbs up.
The phone PS I have generate 90V for the ringer line.(likely less by the time it reaches the house). I was rewiring the house phone lines and someone rang in. It was a pretty good jolt, as I was holding the lines at the time. |
12th Jun 2022, 8:12 am | #24 |
Roger Ramjet,
NO !! it wasnt fence lines, but a single THICK copper wire. From memory ( and I am talking of my memory 60 years ago ) It was hard drawn copper about 1/8" thick ( 3mm in todays dollars, near enough ) Single insulator and not very high above the ground. Perhaps ten foot at the droop point. The same phone line STILL exists!!!, and I have always wondered why some idiot hasnt pinched the copper wire!!. I would show pics except I moved to the next village 3000 kilometres by road north, so I cant take pics today. Joe Last edited by joebog1; 12th Jun 2022 at 8:13 am. Reason: spello |
12th Jun 2022, 8:16 am | #25 |
Peter in Parkes,
That armature doent look in very exciting condition !!. It may be black enamel ( which in itself is a disaster ), but it could be cooked. It is VERY black!!. UNless you have the patience of Jobe, rewinding is out of order. Joe |
12th Jun 2022, 9:13 am | #26 |
Yes the coil does look cooked but I wonder how that could happen even if the output was overloaded. Could it be an incoming lightning strike on the line ? Clearly, the magneto is disconnected until turned - although a high transient voltage would make short work of that !
In any event the bell & capacitor would be first casualty. That said the bell capacitor did look a bit cooked also ? Rog |
12th Jun 2022, 10:00 am | #27 |
I’m not too alarmed as I pulled apart a good working magneto to check its state.
Pics attached |
12th Jun 2022, 10:12 am | #28 |
Good move Peter......cannot see clearly on your piccy's so does the coil on the working unit look similar the the blackened coil on the faulty one ?
Rog |
12th Jun 2022, 10:31 am | #29 |
I'll let you guys be the judge.
13th Jun 2022, 2:31 am | #30 |
