23rd May 2022, 8:27 pm | #1 |
ITR London copper clock.
Good evening. I’m in possession of an international time recording clock /London London copper spun clock. It originally came out of a carpet factory called Brintons. I am trying to renovate it and would like any information possible especially with the coils which I have not tested as yet but I can see on them they are 24 V. I would Appreciate if I knew what diodes/resistors are required. Any advice would be greatly received.
Last edited by GentlemanJohn; 23rd May 2022 at 8:38 pm. Reason: Description mistake |
23rd May 2022, 8:36 pm | #2 |
Re: Ltr london copper clock
Some pictures would help, particularly of the motor and mechanism.
24V motors would be very unusual in an electric clock. Are you sure they're not 240V? |
23rd May 2022, 9:20 pm | #3 |
It's not "Ltr" as the title says, but "ITR" as in International Time Recorders, which became IBM, I think.
Brintons' factory was apparently built in the 1920s, so your clocks probably date from then: https://www.***********/photos/28083135@N06/7139505549 See here for some info on the master clocks: https://clockdoc.org/default.aspx?aid=1903 The "slaves" often worked from 24V DC. I think your clock may be one of these, and needs a specially-timed pulse to drive it. If you don't have a master clock, then little electronic modules are available which work very well: https://www.ebay.co.uk/itm/114785375...BoCaz4QAvD_BwE https://www.electric-clocks.co.uk/Im...ockdrivea.html I have one of the former type driving our big ITR slave clock in the dining room. It works faultlessly, year after year. As Paul's said, pictures please! Last edited by Nickthedentist; 23rd May 2022 at 9:30 pm. |
23rd May 2022, 9:28 pm | #4 |
International Time Recording Company was amalgamated into The Computing-Tabulating-Recording Company (CTR) which, as Nick says, was incorporated into International Business Machines (IBM).
24th May 2022, 10:56 am | #5 |
PM reply sent. David
24th May 2022, 11:06 am | #6 |
Re: ITR London copper clock.
Thread title updated.
26th May 2022, 10:55 pm | #7 |
ITR slave clocks take a 24v pulse every minute. They have three wires connected to the slave unit, which are switched by a microswitch operating on the hour (at least mine do, from 1960s). If this is the case, you might find things easiest if you re-wire the slave coil just across two wires and neglect the microswitch. But mine also use a semiconductor diode in the slave, which yours will not, so perhaps they are very different!
"The best dBs, come in 3s" - Woody Brown |
15th Jun 2022, 6:49 pm | #8 |
Thank you everyone for your information has been greatly received. I am rather busy at the moment and I’ve just read all the messages given to me. Once again thank you very much most appreciated.
