11th Jun 2021, 2:14 pm | #1 |
Sony HMK-40 music. Speakers?
Just claimed a Sony HMK-40 music centre which has been abandoned in a garage for many years. Needs a fair bit of work!! There are no speakers. Can anyone tell me which speakers I should use? You may have realised I am a complete novice. Thanks.
11th Jun 2021, 2:31 pm | #2 |
Re: Sony HMK-40 music. Speakers?
Any 8 ohm HiFi speakers will be fine. The best fit would be something from the same era, the late 70s. Look for anything vintage by Goodmans or Wharfedale - these will sound significantly better than the original Sony speakers.
You should be aware that this unit may need a significant amount of work, especially if it's been stored in poor conditions. As a minimum, all the belts will need changing, and the record deck will need dismantling, cleaning and relubing. |
11th Jun 2021, 4:37 pm | #3 |
In the meantime you can check it out if you have a pair of headphones - most likely the headphone socket will be a 6.3mm stereo jack plug - if your phones are more recent they may have a 3.5mm or even 2.5mm plug on the end, though adaptors are available.
12th Jun 2021, 9:21 am | #4 |
Thanks Paul and Sirius for the helpful advice. It's a little daunting, but nothing ventured....Sure will be back for more help. Thanks again.
