Old 3rd Jul 2014, 9:22 am   #1
Paul Mathew
Default Needing input on an output transformer fault!!
I'm working on a Philips 171A, from a 170A schematic, but it seems identical. The output transformer has a double primary winding c, d, e. The section d - e, has gone open circuit. However, I am getting a clear signal, using a crystal earpiece, on the secondary winding h - j, used to apply feed-back. The secondary winding f-g is producing no signal to the speaker. I'm assuming that I'm hearing the audio from the grid of V4. Is there any quick fix?
Paul Mathew is offline
Old 3rd Jul 2014, 1:02 pm   #2
Herald1360
Herald1360's Avatar
Default Re: Needing input on an output transformer fault!!
You might get away with an ordinary OP TX if you float the LS winding and use that for the F/B as well as the speaker. Adding some extra C to the smoothing (if the rectifier can stand it) could help with the loss of the hum cancellation function.
Otherwise you need a secondhand TX or a rewind
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is online now
Old 3rd Jul 2014, 1:08 pm   #3
Leon Crampin
My fix for the 170A output transformer problem is to fit a further standard transformer to the set - preferably under the chassis as there is plenty of room.
Wire this in the conventional way, but leave the existing transformer in circuit, just disconnect the lead to the anode of the EBL31 to avoid possible intermittent re-connection of the old winding. Now connect the secondary of your new transformer to the secondary of the existing transformer (and of course, the LS and socket).
If you get the phasing correct, the set will operate as designed, the existing transformer being used in reverse to generate the feedback voltages and the hum cancellation voltage.
This scheme works well and also allows proper operation of the tone control.
Leon.
Leon Crampin is offline
Old 3rd Jul 2014, 1:39 pm   #4
Paul Mathew
Thanks, I'll give it my best shot and report back!!
Old 9th Jul 2014, 4:56 am   #5
Paul Mathew
Hi Leon,
Just reporting back! I followed your advice (more or less!) and connected another TX across e - c, disconnecting e from the anode of the output valve. I then connected the secondary of the new TX directly to the speaker and all is working fine. Not sure if I was just lucky here, as I never connected the secondary of the new TX to the old as you suggested?! I assume the feedback loop is still functioning from one half of the old TX's primary ( c - d )??
I'm eager to learn, and am very appreciative of your suggestions!!
Regards, Paul
