5th Jun 2014, 8:54 pm | #41 |
Re: What's the best audio output valve?
At a local fair in our village I once saw a couple of output amplifiers with enormous valves.
They were labeled as Kronzilla KR T1610. What struck me was the fact that the double triodes had their anodes/plates mounted on top of each other. But most of all their absurd size was impressing. A search at the the web gave this information: With its large plate dissipation (150W), the T1610 is much bigger than the 845, the next largest triode made. The Kronzilla tube measures nearly 12" tall, over 3.5" in diameter, and weighs almost two pounds. After hearing the price of the complete set I left the hall with some polite oh´s and ah´s. It was somewhat over my budget. Jard N. |
5th Jun 2014, 9:08 pm | #42 |
5th Jun 2014, 9:13 pm | #43 |
UL = Ultra-Linear. Our friend t'interweb will explain much better than I can.
5th Jun 2014, 9:16 pm | #44 |
It is most impressive- but I fear that both the cheesy moniker and the gold-plating place it outside the forum's remit
5th Jun 2014, 10:10 pm | #45 |
Maybe those Freudian psychoanalysts do know a thing or two?
6th Jun 2014, 9:51 am | #46 | |
Chris
6th Jun 2014, 10:47 pm | #47 | |
7th Jun 2014, 8:18 am | #48 | |
Re: the 6BW6
Then there's always the Codar AT5 which uses a single-ended 6BW6 to drive a 6BW6 output valve. |
8th Jun 2014, 4:49 pm | #49 |
Regarding the several QQV dual beam tetrodes, does anyone know of their use in audio amplification? They are usually VHF transmitter valves but the data sheets say they can be used as AF OP valves.
Not sure if this would be a drawback but I notice that the "screen grids" of each side is connected. Would this present a problem if used as a audio OP valve. Andy.
9th Jun 2014, 9:39 am | #50 |
I'm aware of at least one commercial marine transmitter that uses a 6-40A as a modulator.
The commoned screen-grids aren't a problem - just feed them from a potential-divider between the main anode HT supply and earth, and decouple sensibly. But remember to include lots of "stopper" resistors and ferrite beads in the control-grid and anode circuits, just in case you find you've built an audio-amp that aspires to being a push-pull VHF oscillator. |
9th Jun 2014, 12:37 pm | #51 |
It does rule out ultralinear connection for push pull.
9th Jun 2014, 1:42 pm | #52 |
There's the YL1130 dual beam tetrode with a common screen. As said, it rules out ultra-linear use or even triode connection (unless you parallel both halves of the thing)
What it does have that will get the phools very excited is a directly heated cathode. It was intended for PMR and aviation VHF and the direct heat was for very fast turn on so it didn't need to stay hot. David
9th Jun 2014, 2:10 pm | #53 |
8 or 9 watts in Class C - what'll it do at audio frequencies in AB1?
9th Jun 2014, 2:32 pm | #54 |
The YL1130 is an odd looking valve David in that you can seen the grid windings. is the 8w power out per each side of the total of both sides?
I've accumulated a few of these lesser known dual beam tetrodes such as the QQV03/10 in the hope the one day my knowledge will catch up to the point where I can design an amp around them. These QQV types can be had NOS for a sensible price at present. Andy.
10th Jun 2014, 2:05 am | #55 |
10th Jun 2014, 6:49 am | #56 |
I've seen Chinese designs using a push-pull VHF transmitter tetrode as well as amplifiers using a QQE03/12. Bit like ELL80.
Tjerk, 9ZZ |
10th Jun 2014, 7:55 am | #57 |
I think the 'best' audio output valves are now priced out of the reach of many people who would like to either restore a piece of old equipment, or to learn a bit by building something.
Is current production done as diligently and to the same standards as when these devices were at their peak? It's difficult to judge because people's comments are strongly flavoured by beliefs. What we're seeing now are aficionados looking for other devices because of the rarity and price of NOS preferred types. They're going to work their way through every NOS valve in existence that they can get gain out of. Perhaps the title of the thread would have been better in the past tense... What WAS the best audio output valve? Then answers don't get flavoured by the currently distorted market for such things and can be related back to saner times when people listened to music. David
10th Jun 2014, 8:25 am | #58 | |
10th Jun 2014, 8:44 am | #59 |
That sounds good to me, Richard. I have this feeling that original parts would best be conserved for use in original equipment. If new valves are turning over in any quantity, then decent process control will be needed to get profitable yields, as you say.
The EL84 certainly has a reputation for sound quality and it certainly fits in with several Leaks I've repaired over the years. The only problem is that they discolour at a hell of a rate and look like they're about to fail any moment. They don't of course, but they worry me. After you've done it, why not have a go at a somewhat more difficult task? try designing a good transistor amplifier. It's possible, but it's definitely harder than doing a reasonable valve amplifier. David
10th Jun 2014, 8:44 am | #60 | |
"Ultra-linear" wiring of push-pull output valves always seems intuitively a bit strange to me - since it means you're constrained to using an anode HT-voltage no greater than the valve's maximum screen-grid voltage. |
