26th May 2014, 5:58 pm | #21 |
Re: What's the best audio output valve?
I always used KT66s in the heyday of valve amplifiers but I would think colour TV line output valves would give lots of power although I don't know if their characteristics would suit audio. There are lots of PL509s and 519s about probably for very little money, I have a box of them complete with bases and top caps.
Peter |
26th May 2014, 6:51 pm | #22 |
Is the EL503 an example of Philips's being coy about beam tetrodes? From the look of its characteristics it would seem not to be a pentode.......
29th May 2014, 9:11 am | #23 |
A while back I built a 78 rpm gramophone from 'junk' parts that were literally kicking about in my extensive junk box [s]!
https://www.vintage-radio.net/forum/...ad.php?t=97914 The final version of the amplifier consists of a 6F13 preamp [TV RF amplifier] feeding a 6L6G into a Radiospares 'Heavy duty output transformer'. It gives excellent results on 78 records and recently I fed some test card music via a CD player into the amp. I must say I was astonished by the quality and presence of the audio quality. It is very nice to listen to with plenty of output from the pre war speaker employed. It is all I could wish for. My favorite? It must be the humble 6V6/G, the big black Brimar one with the black anode. That must be the secret or maybe the unknown powers of the little Mazda 6F13.. I may take it to the garden party at Dulwich on Saturday. Regards, John. |
29th May 2014, 9:58 am | #24 |
Is nobody going to suggest the UL41 as a candidate for best output valve then?
29th May 2014, 1:55 pm | #25 |
I bought a load of tiny soviet 1p24b-v pentodes, they're tiny but are rated for 1.3W into 50ohms....On my pile of round tuits is a parallel push pull UL amp.
1st Jun 2014, 4:52 pm | #26 |
Can you do UL with those things? I suppose they have some affinity with beam tetrodes in the sense that all their "grids" are beam focussing rods.
1st Jun 2014, 7:15 pm | #27 |
I was very pleased with an amp I built for an enthusiast. ECC83 strapped as a single triode driving a 6L6GC and a RS Hygrade audio transformer. Class A of course.
2nd Jun 2014, 8:00 pm | #28 |
No- one has mentioned the Mullard EL84 yet. A super valve in my opinion!
Due to recession, the light at the end of the tunnel has been switched off... |
3rd Jun 2014, 11:21 am | #29 | |
D |
3rd Jun 2014, 12:37 pm | #30 |
Agreed. I've just had a notion of using four per channel for my 20W amplifier.
3rd Jun 2014, 1:12 pm | #31 | |
In push-pull you can get 30 watts or so from a pair. |
3rd Jun 2014, 5:22 pm | #32 |
Hands down PL519. Most bang for your buck! And remember, even McIntosh used line output tubes in their designs.
@Herald1360: the EL503 indeed is a beam power tetrode. There's a Funkschau article from 1966 (when it was introduced as successor of the EL34) pointing this out. Tjerk, 9ZZ Last edited by PE9ZZ_JO22KI; 3rd Jun 2014 at 5:30 pm. Reason: Added EL503 info |
4th Jun 2014, 12:40 pm | #33 |
4th Jun 2014, 3:05 pm | #34 |
It's true, that's what Brimar claimed, but working in class AB2.
It isn't recorded how well they last though! The snippet is from the full Brimar datasheet which is too big to post. Pete |
4th Jun 2014, 3:10 pm | #35 | |
Cheers, GJ
http://www.ampregen.com |
4th Jun 2014, 10:04 pm | #36 | |
At the risk of upsetting some people I think the Mullard valve was/is a bit overrated. Probably because I havent heard a new one, most of the ones out there are probably on their last legs. I rather like the Russian 6P14P-EV version, which can take a higher anode voltage and has a higher anode dissipation AfAIK. And I got em for a fiver each................ and yes I think they are a super little valve, 10watts in push pull is plenty in most normal domestic setups despite what the hi fi comics would have you believe. Even with modern speakers. |
5th Jun 2014, 12:08 pm | #37 | |
5th Jun 2014, 1:03 pm | #38 |
When you're driving it from a carbon microphone and the audio-response is filtered to 300-3000Hz either side of the speech-clipper, 7% harmonic distortion's not going to be noticed!
5th Jun 2014, 2:44 pm | #39 |
I think I'll stick with some new Russian 6P14s (EL84), four per side developing about 20W per channel and running nice and cool. RS sell 6P14s for £7 each including VAT even if they are out of stock today!
5th Jun 2014, 7:29 pm | #40 |
Assuming that that's the dominant distortion then with 26dB negative feedback (Harold Leak managed that back in the 1940's) you'd be down to 0.35% which isn't too bad. It's the same as the EL84-based Mullard 5-10 when that's operating at just 10W and it's three times better than the stock version of the much loved Mullard 3-3, for example. If you drop down to 25W then the distortion drops by another factor of two (see the graph on the 28th page of the Application Report) and I reckon you could make a decent case for that being hi-fi .
Cheers, GJ
