Old 21st Feb 2019, 5:06 pm   #21
bionicmerlin
bionicmerlin's Avatar
Default Re: Philips 19 inch tv info please
I’m going to put it away for a bit to finish off other things . But I will get a few bits in the mean time. Can someone tell me the value of this capacitor as I can’t find a converter on line that works ref number c 452 as I don’t have a circuit diagram. Thanks Andy
bionicmerlin is offline
Old 21st Feb 2019, 5:37 pm   #22
dazzlevision
220nF,250Vdc, 20% tolerance, Polyester dielectric.
dazzlevision is online now
Old 21st Feb 2019, 5:40 pm   #23
jayceebee
jayceebee's Avatar
Hi Andy, it's a Mullard C280 series polyester film capacitor 0.22uF 250V 20%, the attached page from on old Mullard data book should help you. They were known as Tropical Fish capacitors, I'm afraid I don't have a manual so I don't know what C452 does.
John.
jayceebee is offline
Old 21st Feb 2019, 7:20 pm   #24
Maarten
Tropical fish capacitors aren't necessarily defective even when cracked, but it won't hurt to replace.
Maarten is online now
Old 21st Feb 2019, 11:25 pm   #25
bionicmerlin
Thank you all. I have just printed out the ref chart . Thanks John.
I see where I was going wrong .to the untrained eye it looked like the top was one red band when infact it is two bands in one Andy
Old 20th Mar 2019, 4:41 pm   #26
bionicmerlin
I have got the tv out again after replacing a few obvious faulty items . Before firing it I thought I would disconnect the power supply from the main chassis. I put a 1 amp fuse to test it . On power up on a variac it blew the fuse but I did see the glow switch thing flash indicating a over voltage that made the fuse blow. Thé rectified is a replacement ,radio spares rec 65A and the thermistor is part number C122D . Again a replacement .
The original should be BT100A/500R . The rectifier tests ok so can I assume thé thermister is faulty.
If this is the case what’s the best one to use these days and is it also worth changing the rectifier anyway . Again what’s the best part to use
Thanyou anyone helping me Andy
Old 20th Mar 2019, 5:16 pm   #27
Maarten
I think I've seen a C122D thyristor (not thermistor) being used as a factory original replacement for the BT100A in continental sets.
Old 20th Mar 2019, 6:48 pm   #28
Welsh Anorak
Welsh Anorak's Avatar
Yes, it's a thyristor (silicon controlled rectifier or SCR). I think the BT106 (still available) is a suitable replacement for the BT100. Back in the day there were loads of alternatives such as the TV106, the RS one you mention and the 2N4444 in a plastic package, the latter being about the most reliable.
Glyn
www.gdelectronics.wales
Welsh Anorak is online now
Old 21st Mar 2019, 10:52 am   #29
Heatercathodeshort
Heatercathodeshort's Avatar
Just a minor point. The glow switch can become faulty in itself, firing before the correct HT has built up. Probably worth checking the HT on the glow switch in combination with a variac. J.
Heatercathodeshort is online now
Old 22nd Mar 2019, 3:26 am   #30
bionicmerlin
Thanks for the info every one.
John i checked the glow switch by checking the HT output . It should be 163 volts.i let thé voltage get up to 170 volts and it hadn’t activated. At that point the output voltage from the variac was roughly about the same.
I will get a replacement BT106 and give that a try Andy
Old 2nd Apr 2019, 3:05 pm   #31
bionicmerlin
Slow progress update.
I have replaced the thyristor. After powering up on the variac at the same time checking the voltage and a little tweek on the voltage adjustment pot all’s well from that sidérons things
I’m now on to the next problem . Not quite I thin line across the screen but about 3/4 or a inch slightly ragged. I take it the next thing is checking the output transistors.
On the plus side the sound is good.
Any more help we’ll appreciated Andy
Old 5th Apr 2019, 12:36 pm   #32
bionicmerlin
Had a little set back .the set died altogether but traced to a faulty 220k resistor on the power supply.
Can someone comferm my readings that the BU105 is suspect as I’m getting what appears to be 136 volts on the base when I think it should be less than 1 volt.
Other transistors appear to have the correct or not far out voltages going on the circuit diagram.
I also believe the BU105 should be upgraded to a 205 . Thanks Andy
Old 5th Apr 2019, 11:41 pm   #33
bionicmerlin
Please disregard my last post. Due to my inexperience I gave the incorrect voltage. Infact the voltage is spot on. So anymore tips please .andy
Old 10th Apr 2019, 11:46 am   #34
Electricdreams
Electricdreams's Avatar
What a beautiful set! I think I've seen a similar one on Victoria Wood's As seen on tv.
Have you checked for dry joints?
What have you bought now??
Electricdreams is offline
Old 12th Apr 2019, 2:51 am   #35
bionicmerlin
I did check for dry joints .all looked pretty good.
But a bit of success just found a open circuit capacitor, that’s done the trick
It still wants a bit of work as the hight And linearity pots is at the end of their travel,slight width problem and minor screen jitter but I’m getting somewhere Andy
Old 4th May 2019, 9:33 pm   #36
bionicmerlin
I think this is about as good as I’m going to get .i have had to tweek a few resistors to get the hight and linearity half reasonable. I know it’s not perfect but the way I see it the more I do the more chance of cocking things up.Twice I had components fail after half hour so it’s been a bit of a challenge to myself . I’m not happy as I have had to run the set without the glow switch as one of the legs was so badly corroded it turned to dust . I’m sure it’s impossible to find a replacement. The set has been stored in very damp conditions quite a few components fell to bits.
Thanks to everyone who helped me Andy
ID:	182483   Click image for larger version
