Old 18th Aug 2019, 9:05 pm   #1
bionicmerlin
bionicmerlin's Avatar
Default Ultra 6816 portable Thorn BRC
We had one of these sets when I was younger Infact it was a grey Marconi. I actually like this white one better . It works well apart from I can’t get the linearity just right. I’m probably being a bit fussy and I might leave it as it is unless I’m missing something? . The picture appears to be very slightly stretched on the left slightly increasing after about 5 mins then staying stable.
It also has poor sound but that’s the speaker and I have a spare one .
Any ideas . Thanks Andy
ID:	188549   Click image for larger version
ID:	188550   Click image for larger version
bionicmerlin is offline
Old 18th Aug 2019, 10:16 pm   #2
Tractionist
Default Re: Ultra 6816 portable Thorn BRC
I think that the white coloured versions were called Ultra 'Bermudas' ?
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline
Old 18th Aug 2019, 11:50 pm   #3
KeithsTV
KeithsTV's Avatar
Boots also sold a version with a white cabinet.
I've had the Ferguson version since 1976 and recently had to change the speaker. I've also had a dry joint on one of the rectifiers which caused a hum bar. Apart from those faults it's been a reliable TV.
Keith
KeithsTV is offline
Old 19th Aug 2019, 9:14 am   #4
Restoration73
Restoration73's Avatar
Try reducing height and adjust for best linearity - it might help to move the raster using
the picture shift magnets. I remember this sometimes helped with the teletext lines.
Check the AC187/188 o/p pair (later versions had silicon) if the speaker is OK.
I have noted the plastics used on Thorn sets can become brittle. (1590/91 chassis)
Restoration73 is offline
Old 19th Aug 2019, 8:14 pm   #5
bionicmerlin
Thanks for the info guys. I will have a better play about to see if I can get it any better thanks Tony for the technical advice Andy
