9th Aug 2019, 5:20 pm | #41 |
Re: First Television to use ICs
Was the SL901 exclusive to the single chip A823, don't recall seeing it elsewhere.
10th Aug 2019, 12:40 am | #42 |
The first IC that I changed was in a EKCO / Pye B/W set for a local dealer and before solder suckers and solder wick! I think that it was for sound demodulation.
The early RBM A823 used a SL901 with 20 pins and a heatsink, later sets used the SL901B which had 24 pins and no heatsink. All the sets that I saw with the SL901B also used the SL917A for chroma etc. RBM produced a meter to set up the level of burst / chroma with 3 leads, I still have one somewhere but it has been a long time since I last used it.
Best wishes, Geoffrey. |
10th Aug 2019, 5:12 am | #43 |
15th Aug 2019, 2:20 pm | #44 |
Yes - the CTV174D proudly proclaimed "IC Colour Lock" on the front panel!
The SL901 originally used was mounted on the 'wrong' side of the decoder panel and had the heatsink horns coming out of it. Pre solder wick, most panels were badly damaged when someone had used a 50W Weller to remove it. The power supply, IF and timebases were pure CTV25/162 Mk3, but the decoder and output (now RGB and transistorised) panels were completely redesigned. I wondered if the use of the SL901 was to road test the IC before using it in the A823? |
15th Aug 2019, 2:48 pm | #45 |
Re Glyn's comment on the SL901, was it now! I thought it was made for the 823. I was in the trade even then but I dont recall it's use in the earlier chassis.
But I remember the Australian PCL82 in the Bush TV125 (upside down) Strange how some things stick in the mind and some don't. And that caused issues being inverted. Cathode coating falling off perhaps? Sets seemed happy having their valves horizontal though. |
15th Aug 2019, 5:29 pm | #46 | |
Greg.
Picture, sound?, DOOR. |
