4th Mar 2019, 11:43 am | #121 |
Re: Extinct or very hard to find sets (625 lines to 1990)
That's slightly odd (post #120), as most of these used those dual concentric on/off - vol and contrast-brightness controls at the bottom. This has four controls at the top which is like the 2040 series colour, but also has a VHF tuner!
We have a late-ish 2000 series in the shop which we keep meaning to have a look at. |
4th Mar 2019, 2:51 pm | #122 |
I guess like Thorn with their later 1400s they utilised the same cabinets as the single standard equivalents.
Would be interesting to see what chassis the GEC dual uses. I guess the late '60s all valve 2000 series with the five position VHF tuner. The front style rather reminds me of the 2028 colour sets. |
4th Mar 2019, 4:20 pm | #123 |
4th Mar 2019, 4:43 pm | #124 | |
The chassis will be the final GEC/Sobell dual standard all valve type (which is a development of the GEC 2000/Sobell 1000 series) where there is a single horizontal metal "chassis" containing two PCBs and the mains dropper is mounted on a bracket above the IF/sound/video/sync panel. The VHF tuner is a GEC/Sobell in-house development incremental inductance type, with five positions (2 x Band 1, 2 x Band 3 and 1 x UHF - IF pre-amp). The four pushbutton UHF tuner employed Silicon transistors. Last edited by dazzlevision; 4th Mar 2019 at 4:53 pm. |
4th Mar 2019, 6:06 pm | #125 |
I've never seen this design before. I assume from the model number they were the very last ones to use this chassis and were concurrent with the Series One for areas that hadn't fully switched to 625.
5th Mar 2019, 8:04 am | #126 | ||
I imagine that the incremental cost of adding FM capability to a UK dual-standard monochrome receiver was a bit less than it had been for the 405-line only case. The VHF tuner requirement (i.e. with Band II as well as with Bands I & III) would have been essentially the same for both. But whereas the 405-only receiver would have required a change to a dual-mode (AM and FM) and usually dual-frequency (38.15 and 10.7 MHz) IF strip, such was already in place (with 38.15 and 6.0 MHz frequencies) for the dual-standard TV receiver. That assumes that 6.0 MHz was used as the FM IF, but I understand that that was usually the case. On the other hand, once single-standard, UHF-only 625-line receivers arrived, adding FM would have been more costly. A separate FM front end would have been required, modified for 6 MHz IF output, and perhaps an additional IF stage. By then perhaps demand for TV-FM combinations had dwindled anyway. Turning to possibly or probably now-scarce TV receivers from the period at interest, I should not be surprised if the Beovision 1600 24-inch monochrome model (625-only) fell into that category. Cheers, |
5th Mar 2019, 9:34 am | #127 | |
5th Mar 2019, 10:18 am | #128 | |
In the GEC/Sobell brochures I have, from the 1969-72 period, they offered dual and single standard large screen monochrome sets, to cater for the areas that weren't yet covered by three channel UHF/625/PAL transmissions (of BBC1, BBC2 and ITV), which commenced in November 1969. Most of the other UK TV manufacturers did the same. |
5th Mar 2019, 10:27 am | #129 |
I'd have to agree with the earlier comments in this thread, that the 110 degree delta gun TVs of the mid 1970s didn't produce pictures as good as their 90 degree counterparts (not even those from B&O or Tandberg, in my opinion).
The pictures tended to be less sharp and the tubes soon exhibited poor focus, especially outside the central area. I have a 26" Pye colour set fitted with the (110 degree delta gun) all transistor 747 "chassis". These sets appear to be very rare in collections nowadays. This was the last Pye designed chassis. Subsequently, they adopted the Philips G11 chassis (following the cessation of the ten year "arms length" control Philips had over Pye, when they acquired a 70% controlling interest in 1967). |
6th Mar 2019, 11:08 am | #130 |
Even rarer would be the 22" Pye fitted with the similar solid state chassis. Most were fitted with the conventional A56-120 and the 725 chassis but this had the 110 degree A56-140 CRT and the 741 chassis. I can't bring to mind another British made delta-gun 110-degree 22" set.
Again, the pictures were't as good as the 90-degree set (in my opinion) and the extra circuitry made these pretty unreliable.The last 90-degree 725s weren't too bad, but not Pye's greatest effort. |
6th Mar 2019, 12:18 pm | #131 | |
As to any other British made delta-gun 110-degree 22" sets, I did have a 22" set fitted with the Rank Z179 chassis (it was an export model, for the Irish market and so had UHF and VHF tuners fitted), fitted with a Mullard A56-140X CRT. |
6th Mar 2019, 2:50 pm | #132 |
22" Rank Arena Z179 chassis CTV
6th Mar 2019, 2:59 pm | #133 |
6th Mar 2019, 3:59 pm | #134 |
For those unfamiliar with the construction of the Pye 731 to 747 (110 degree CRT) and 725 (90 degree CRT) chassis, here's a photo of it. The 725 is shown.
6th Mar 2019, 5:39 pm | #135 |
I have the full service manual for the Z179 which was an odd mixture of designs. The PSU, IF and decoder was like the late A823, using an SL901 and SL918 while the output stage was more continental in design. I never knew they made a 22" one, the manual referring to the 26" version, of which I serviced one or two back in the day. They were the flagship Bush sets then, like the A816 mono. Anyone know why the chassis were prefixed A, Z and then T?
6th Mar 2019, 5:41 pm | #136 |
The 22" Pye 110-degree was a fairly ugly beast with slider controls and a seven (I think) push-button tuner similar to the ITT and other European sets of the period.
7th Mar 2019, 11:27 pm | #137 | ||
Somehow it is the kind of receiver that one might have expected Dynatron to offer, given that before the dual-standard era, it seemed to have paid quite a bit of attention to detail in its (405-only) TV-FM receivers. For example, the TV50, of the early 1960s had AFC not just for FM, but also for TV, obtained from the AM sound channel (using a discriminator that also appeared to double as an AM detector). But I haven’t seen any evidence that Dynatron participated in this little corner. Cheers, |
8th Mar 2019, 12:45 pm | #138 | |
Loss of colour when warm. It was a cap by the thick-film. I'm amazed I can remember that. It was 38 years ago!
andydoz.blogspot.com |
8th Mar 2019, 3:05 pm | #139 |
Talking of the sold-state Pyes, it appears the original 110 degree set needed 0.9 service calls a year whereas the final 725 90-degree sets needed only (!) 0.51 calls per year. This apparently put them in line with the Japanese manufacturers. I imagine Messrs. Sony, Hitachi and Toshiba had a good laugh at that 'fact'!
8th Mar 2019, 6:07 pm | #140 |
I vaguely remember Autovox being an in-house brand of Comet, as was the case with Solavox.
