30th May 2018, 2:35 pm | #1 |
UNAOHM TV Field Strength Meter
Folks,
Just been given a UNAOHM EP 730 B FM fsm. To my TV ignorant experience, it seems to work OK basically when switching on. No evidence of any physical damage. But I'm reluctant to delve further. Any info or pdf documentation most welcome please. With a bandwidth of 45 to 860 MHz, I'm guessing this early 21st century item(last tested 2003), could still be used today ? Regards, David |
1st Jun 2018, 2:42 pm | #2 |
Re: UNAOHM TV Field Strength Meter
Er, do you mean coverage from 45 to 860 Megs?
It should still work when tuned to the local digital TV multiplexes (470 to 700 Megs) and also digital radio - around about 220 Megs. The precise frequencies depending upon which transmitter is within range. |
2nd Jun 2018, 11:12 am | #3 |
Yes Steve - coverage bandwidth. Right enough, even just a loose wire connection into the BNC socket, produces a lock-on of sorts in those UHF frequencies on a few channels. But they are too indistinct to identify. Perhaps using a portable booster aerial or connecting it to my chimney's Yagi would produce a much better picture.
However, I'm giving it to a local vintage chum who is a keen TV buff. Had I the Manual, and had learnt that other Forum folk had found an alternative non-TV use for Unaohms, I might have considered using is as some sort of Spectrum Analyser or wavemeter for VHF/UHF signal generators, or Tx's. My Marconi TF 995A/5 AF/FM Sig Gen for example, or Amateur Radio chum's 2m rigs. Just a thought, as it is in too good a nick as a nice piece of test equipment. Regards, David |
