Old 25th Apr 2018, 6:37 pm   #1
rogerdup
Default Globe Television project (mechanical)
Hello Gentlemen,
Some friends ask me to go again on a mechanical TV project. I found on the ETF pages a link to the hawestv.com literature.
The Globe Television Corp. Us midget set made in 1932 described there caught my attention. Only poor photos of this set are available I think. Based on the size of the tubes appearing on the back, I could imagine the average size of the machine that is :64cm high, 45cm width, 30cm depth. A big midget. The nipkow/brillouin scanning disc is 30cm diameter and made for 60 lines.
So, I think to get started with it, but first need to understand how the crater lamp and the lens were acting together to project the 4x5 inches pictures.
If somebody has info about this, I would be very grateful.
No problem to make a similar cabinet, nor for finding the bulb lamps.
Roger
ID:	161804   Click image for larger version
ID:	161805   Click image for larger version
rogerdup is offline
Old 25th Apr 2018, 7:53 pm   #2
Dave Moll
Dave Moll's Avatar
Default Re: Globe Television project (mechanical)
You might also find this a useful site.
Dave Moll is offline
Old 25th Apr 2018, 8:19 pm   #3
peter_scott
peter_scott's Avatar
You can get valve list here.
You weren't far off with the dimensions.
http://www.americanradiohistory.com/...32-May-Jun.pdf
Page 103 says that the scanning disc has 60 lenses (not just pin holes).
See also the projector at the foot of page 105 and article on page 108 not mention page 87 and few others.
Peter
peter_scott is offline
Old 25th Apr 2018, 9:11 pm   #4
peter_scott
1931 Nov/Dec Television News page 338 article on crater tubes.
1932 Television News Sept/Oct page 190 there's an article on crater lamps and the next article is on Lens Disc Design.
Peter
Old 25th Apr 2018, 9:46 pm   #5
rogerdup
Thanks Dave and Peter. Reading the litterature, this lens scanning disc appear very complicated to make, and I think we wil have not sufficient skill to go through it. Fist difficulty: find 60 lens correct type for this application!
Thanks for reminding me the Radiomuseum source..I got the real sizes
Roger
rogerdup is offline
Old 26th Apr 2018, 7:58 pm   #6
rogerdup
First step, on the way to build the prototype: the bulb shaped valves.
From left to right:
UP:
Two 24 tetrode RF amplifier
One 80 rectifier
LOW:
27 detector,
24 1st préamplifier,
27 2nd preamplifier
47 power amplifier (the originals 45 not affordable)
47 power amplifier. The p.a. tubes connected in parallel.
To be continued (I think..)
Roger
Name:	Tubes for Globe Prototype.jpg
rogerdup is offline
Old 27th Apr 2018, 1:03 pm   #7
wd40addict
wd40addict's Avatar
Interesting it seems to have been at least partially designed by Alan DuMont. Later to get into CRTs and become the main US oscilloscope manufacturer. He later crashed his eponymous company by trying to break into domestic TV. Tek took the scope market and the rest is history!
wd40addict is offline
Old 27th Apr 2018, 4:48 pm   #8
rogerdup
At least as interesting as trying to re-construct the machine, is the history attached to it !
rogerdup is offline
Old 28th Apr 2018, 3:15 pm   #9
peter_scott
In the same magazine as your Globe article there is "Own Lens Disc!" on page 87. This describes lens of about 12 mm diameter with focal lengths 28 to 50 mm. You could get similar spec lenses off the shelf e.g.
https://tinyurl.com/y8k3mdgh
Although for 60 you might need to pay £270.
Peter
Old 28th Apr 2018, 7:08 pm   #10
rogerdup
Thank for the link Peter.
270 L is not an investment I can afford for this project.
Regarding the 30 centimeters of the scanning disc diameter of this machine, I calculate the window picture to be 11 millimeters high by 16 millimeters wide. This really very small and need a drill tool diameter of 0.18 millimeter diameter for punching the hole as a reference for centering the lens. I have not been facing such reduced window in my previous 60 lines prototypes and I am not sure to be able to get through this as said before.
I have ordered lens of 7mm diameter with focal 11mm for test.
Anyway a good new: found a DC motor 1600rpm -37 volts, suitable for driving the scanning disc and to be synchronized by a PLL.
Roger
Name:	moteur projecteur ciné versing.jpg
rogerdup is offline
Old 29th Apr 2018, 7:44 am   #11
rogerdup
I am thinking to put in place of each hole a 3mm led very low angle.
All connected in parallel. I think they would be similar to the light that was passing through the lens.
To be tested today finger crossed..
rogerdup is offline
Old 29th Apr 2018, 8:18 am   #12
julie_m
Nice bit of lateral thinking there!
I see no reason why moving the actual light source, rather than an aperture in front of a single, fixed light source, shouldn't work .....
julie_m is offline
Old 29th Apr 2018, 9:04 am   #13
peter_scott
Excellent idea!
Peter
Old 29th Apr 2018, 4:41 pm   #14
rogerdup
I am not sure that this solution will work but anyway the fun is in experiments.
I will tell you what happen.. keep the suspense on
I had no time to test it today, I was in the radio club sorting an testing bulb shaped valves most of them dud.
rogerdup is offline
Old 29th Apr 2018, 5:08 pm   #15
Panrock
Panrock's Avatar
All connected in parallel./
Hi Roger. How are you going to connect them to power, on the moving disc?
Or maybe I have misunderstood...
Steve
Panrock is offline
Old 29th Apr 2018, 6:56 pm   #16
Dave Moll
Dave Moll's Avatar
I remember a display some years ago at the NBTV Convention using a drum of LEDs. Unfortunately, I don't recall whose it was nor how they supplied power to the LEDs, though presumably it used a sliding contact to connect to whichever row of LEDs was in the display position. A similar arrangement could probably be used around the disc, lighting each LED in turn.
Old 29th Apr 2018, 8:42 pm   #17
julie_m
If there is an aperture mask in front of the disc, then there will be no need to have only one LED lit at a time. The whole chain could be connected in series or parallel, and modulated alike; only the diode in the aperture will contribute to the visible image. And it's probably using less power having 59 LEDs that nobody is going to see, than the heater of the valve that is amplifying the video signal with which they are driven .....
julie_m is offline
Old 29th Apr 2018, 8:47 pm   #18
Dave Moll
Dave Moll's Avatar
True, the drum display I saw didn't use an aperture mask.
Old 29th Apr 2018, 8:57 pm   #19
rogerdup
I Steve and Dave,
For the leds I need only use two wires and one going from one to the other. There is two thin wires going from first led to last led fixed on the disc. At the end the two wires goes close to the shaft and one connect to a brass circular plate with a spring contact.The other wire connect to the ground. So is also the motor shaft and no other special circular contact is needed for this one.
If the 3mm led is for 3v5, That's for 60 in serie a 210 volts to feed them. Seems to be compatible with my idea to drive them with a vintage valve 47 type.
Hi Julie,
Right. I will use a windows aperture very small on a 30 centimeter scanning disc. I plan to display on a grounded ? sanded? glass.
rogerdup is offline
Old 29th Apr 2018, 9:09 pm   #20
julie_m
True. I was doing my own calculations in my head, and it seemed reasonable to drive a series string of LEDs directly from the anode of a valve like that. Though I was estimating 180V
If you find you have not got enough HT to light 60 LEDs in series, you could always split them into two strings of thirty (perhaps with separate series resistors to help equalise the currents and therefore the brightnesses), or a string of 30 parallel pairs.
julie_m is offline
