15th Feb 2023, 10:55 am | #21 |
Re: PYE P75 radio conversion to guitar amplifier
15th Feb 2023, 12:33 pm | #22 | |
https://www.service-data.com/product...91/6649/t15391 Lawrence. Last edited by ms660; 15th Feb 2023 at 12:41 pm. Reason: extra info |
15th Feb 2023, 1:36 pm | #23 | ||
15th Feb 2023, 3:50 pm | #24 | ||
15th Feb 2023, 3:52 pm | #25 | ||
ISTR that the Fenman ll does the same thing with an ECH81 Mike |
15th Feb 2023, 4:07 pm | #26 |
With an extra gain stage I would suggest some extra HT filtering for its anode feed supply.
Lawrence. EDIT: Yes Mike it does. Lawrence. Last edited by ms660; 15th Feb 2023 at 4:13 pm. Reason: extra reply |
15th Feb 2023, 4:13 pm | #27 | |
EF41 might be designed as an RF amplifier, but it will of course amplify audio frequency signals too. Audio is about the least demanding task we ask amplifiers to do! |
15th Feb 2023, 5:07 pm | #28 | ||
15th Feb 2023, 5:14 pm | #29 |
Another alternative is to do what I do - a Ferrograph valve reel-to-reel with integrated loudspeaker serves as my practice amplifier and bedroom record player amplifier. I got the player on Freecycle, and it has the advantage of being able to record anything you're particularly pleased with.
15th Feb 2023, 5:39 pm | #30 | |
15th Feb 2023, 8:45 pm | #31 |
Out of interest, there's some Ia-Va curves for the EF41 in the link below (Vg2 @ 100 Volts) the reason for posting the link is that the curves aren't shown in the Philips valve data:
https://frank.pocnet.net/sheets/050/e/EF41.pdf Lawrence. |
15th Feb 2023, 9:42 pm | #32 |
My friends and I used domestic wooden radios in the sixties with electric guitars. We couldn't afford the "proper" amps [as advertised in Practical Wireless.] Using the pick up sockets we got a reasonable sound out of them on 2 or 3 watts. [pre Marshall amps proper bands got a great sound out of much less than 30 watts]. As the "woodies" were still valued in themselves back then and salvaged Loudspeakers were cheap, we connected up external speakers in home made cabinets... to avoid damaging the one in the set There were transistor pre-amps about but we didn't have any.
Dave W I also had a relatively cheap tape recorder with a "PA" function switch that isolated the amp section to use on its own with a microphone [Garden Parties?]. Once again I hooked up an alternative spkr [utilising a cabinet from a wind up Gram]. With a donated "hum bucking" single pickup on a home made guitar [also free] everything overloaded beautifully. Sadly my playing expertise didn't quite match up to the Claton/Hendrix sound. Last edited by dave walsh; 15th Feb 2023 at 9:54 pm. |
16th Feb 2023, 10:57 am | #33 |
Hello,
Dave's post reminded me of a picture in the Mo foster book British Rock Guitar. I’ve attached photo of part of the relevant page in the book, I’ve kept the image closely relevant to the conversation, but if the mods feel it's infringing any copyright, then all means remove it. I’m finding there is fine line between small lower power guitar amplifiers made by the likes of Fender and Rickenbacker [dating back to the 1950/60's] and the amplifiers used in 1940/50’s Table Radios and Radiograms. Terry |
16th Feb 2023, 12:18 pm | #34 | |
16th Feb 2023, 1:07 pm | #35 |
That said, I might as well use the existing screen grid supply as is, no need to change it.
16th Feb 2023, 1:44 pm | #36 |
There's an article for small signal amplifying pentodes in the link below:
https://www.valvewizard.co.uk/pentode.html Lawrence. |
17th Feb 2023, 2:09 pm | #37 |
Hi again, I've put the attached schematic together, combination of extracts from various circuits, but it should be easy enough to interpret. Wasn't sure about whether C18, C19 & R9 were still needed, so any advice would be greatly appreciated. Also whether I've made any obvious errors with the first stage layout & component values. |
17th Feb 2023, 2:54 pm | #38 |
I would include an coupling capacitor in series with the input to the 1 Meg pot and also an extra HT filter resistor say initially 10k connected in the HT rail just to the right of the 16uF in your schematic.
The other alternative using the same valve (EF41) is to connect the control grid (g1) to the anode and operate it as a triode, characteristics wise the EF41 isn't that far removed from the pentode section of the EAF42, typical resistor values for that one for triode connected are given in the link for either using cathode bias (page 44) or grid current bias (page 45) those values might need fiddling with as they are given for an HT supply voltage of 250 Volts and I think in yours the HT might be lower. https://frank.pocnet.net/sheets/046/e/EAF42.pdf Good luck whicheverways. Lawrence. |
17th Feb 2023, 3:42 pm | #39 | |
Interesting also is the option of using the triode section of the ECH42 tube, which it seems can also be used as an audio amplifier. Nice to have a few options to play with. http://www.r-type.org/pdfs/ech42.pdf Last edited by RogerLLL; 17th Feb 2023 at 3:44 pm. Reason: addition |
17th Feb 2023, 3:52 pm | #40 |
Yes, as in the Pye P53.
Lawrence. |
