11th Sep 2020, 8:58 pm | #1 |
Brimistor C26 Thermistor
I wanted to build a GEC 88-50. It used the 5U4G rectifier and so has a thermistor 3000/30 Ohms. Can anyone suggest a modern alternative or a different rectifier type, maybe indirectly heated that would fit the bill. John |
12th Sep 2020, 3:16 pm | #2 |
Re: Brimistor C26 Thermistor
Wouldn't you be better off with SS rectification? That is unless you have the mains tfmr already. Better than valve rectification, cheaper.
If your set o valve rectification there's a CV something or other that is a 5U4G equivalent, i have one somewhere if you want it, 5U4G's have a cult status CV equivalents in different envelopes don't and are cheaper. Andy.
12th Sep 2020, 3:22 pm | #3 |
The thermistor will be a CZ6. This may aid your search.
As far as rectifiers go, the GZ37 is probably a fair indirectly heated replacement for the 5U4. You would need to check the detailed operating conditions and pin out. You may also need fairly deep pockets - some people out there obviously like them... Leon. |
