20th Apr 2010, 7:39 pm | #1 |
An odd battery
One I have never come across before.
Berec 659 inert cell. On the back it says, Remove cork and vent plug and fill slowly with fresh drinking water. Anyone seen one before? What were they for? |
20th Apr 2010, 8:20 pm | #2 |
Re: An odd battery
There were cells which didn't produce power, but dropped a constant voltage when current was passed through (a sort of electrolytic Zener diode). Could it be one of these?
20th Apr 2010, 8:29 pm | #3 |
Re: An odd battery
Or could it be a salt cell ?
20th Apr 2010, 8:34 pm | #4 |
Re: An odd battery
I think the cell is filled with dried potassium hydroxide - this is then turned into a liquid electrolyte paste with the addition of water.
I think this was done to give the cells a long shelf life.
21st Apr 2010, 6:04 am | #5 |
Re: An odd battery
21st Apr 2010, 7:53 am | #6 |
Re: An odd battery
My initial thought when I looked at the photo was it looks like a NiFe cell. We had them in the science labs at school in the early '70s.
21st Apr 2010, 12:40 pm | #7 |
Re: An odd battery
Aren't NiFe cells rechargeable and pretty much everlasting anyway? Also they only output about 1.2V.
I think the "long shelf life" theory sounds most plausible. A bit like the "air" cells that are activated by peeling off a vent seal or dry charged car batteries.
21st Apr 2010, 3:04 pm | #8 |
Re: An odd battery
I dont think it was a constant voltage cell. The only ones I remember and the most common, were the Weston cell and it certainly isnt one of those.
It appears to have been well used, with several different lines around the cork. So, I decided to try the obvious. Pour in tap water and see what happens. To my surprise, no, amazement, it produces 1.3-1.4 volts (for some reason it varies), and happily runs a 1.35v torch bulb. (It is marked, 1.5 volts.) I cant see inside to check the construction, but when I can find my litmus paper, will see what the ph is of the water now. |
21st Apr 2010, 3:18 pm | #9 |
Re: An odd battery
I've got a physics book from the 50s which talks about a Gordon Magnesium Cell. The negative electrode is a magnesium rod and the positive electrode is a carbon cylinder and the electrolyte is tap water. It says they were only expected to deliver about about 100mA and were used in deaf aids.
That's the only place I've ever heard of it. Presumably, a cell like that would have definite advantages which made it useful in some applications, such as indefinite shelf life and ease of activation. Pete. |
21st Apr 2010, 3:38 pm | #10 |
Re: An odd battery
Hello,
There are standby batteries which need a long shelf life and to prevent self discharge are supplied dry and are only activated on addition of water. See :- http://www.mpoweruk.com/water.htm Yours, Richard |
21st Apr 2010, 5:13 pm | #11 |
Re: An odd battery
I bought one of these ex-gov from Jobstocks in Walthamstow in '67. As a kid I thought it would last forever....just keep replacing the water. Not so, of course.
Does anyone else remember Jobstocks? If so we had better start a new thread. Cheers, Peter |
21st Apr 2010, 5:47 pm | #12 |
Re: An odd battery
Many thanks Richard.
I was sure someone would know. |
21st Apr 2010, 9:15 pm | #13 |
Re: An odd battery
I had a batch of these given to me by my uncle when I was a boy, I added water and they certainly worked, (getting the water in was fiddly) but all my torch bulbs (my 'toys') were 2.5v or 3.5V and so I lost interest when they only lit-up dimly.
I still have them somewhere.
Kevin |
22nd Apr 2010, 12:11 am | #14 |
Re: An odd battery
I also have one somewhere, salvaged from a derelict part of a hotel in India!
I believe they are a standard Leclanche cell, just dessicated until activated. |
6th May 2010, 6:44 pm | #15 |
Re: An odd battery
Not seen this one before from BEREC, British Eveready export company. Im sure i have seen something like this battery that was used by the army but you could urinate in it to activate it in an emergency, I have seen a cell like this in an Antique shop an thats what the old bloke who worked in there told me. It had a MOD arrow on it. I dont think this battery featured here is one of these as the one i saw was made of metal. I could be wrong but it may have been made this way so it would not degrade with electrolite. You added it when you wanted to use it. There is another battery called the Aston cell that you added water to charge, It is a ceramic jar with a dolly wrap core with a carbon rod for + and a zinc rod -. It has The Aston WO Cell water only required to charge this cell written on it. I will post a pic on F Book site at some point.
