Old 29th Jan 2023, 6:30 pm   #1
Bri8691
Default Grayshaw SG50 signal generator
Hello!
I have bought a Grayshaw SG50 signal generator - and there seems to be very little info online!
It has 2 tubes in it - a 8D3 6AM6 - (which I found online) and another just marked ā€˜4E4ā€™ (which i can find nothing about..) Iā€™m very new to this - so any help / info on the 4E4 much appreciated.
Thank you,
Brian
Bri8691 is offline
Old 29th Jan 2023, 7:22 pm   #2
Default Re: Grayshaw SG50 signal generator
From an old advert, two Z77's.
Name:	Screenshot (173).jpg
Old 29th Jan 2023, 7:45 pm   #3
Cobaltblue
Cobaltblue's Avatar
The only 4E4 i can find has a CT base.
https://www.radiomuseum.org/tubes/tube_4e4.html
It would be an odd choice any chance of aome pictures of the inside of the genny?
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 30th Jan 2023, 6:00 pm   #4
Bri8691
Thanks ms660, I see the 8D3 6AM6 is the equivalent of a Z77 - the '4E4' is strange one - perhaps its a red herring, and the ID legend is missing somehow? although i assumed it would be etched into the glass..?
Thanks for the info Lawrence!
Quite by coincidence, I visited L.F. Hanny's shop in Bath, a few times in the 80's!!
ID:	272452   Click image for larger version
ID:	272453   Click image for larger version
Last edited by Station X; 30th Jan 2023 at 10:19 pm. Reason: Linked images converted to thumbnails.
Bri8691 is offline
Old 30th Jan 2023, 10:43 pm   #5
Lucien Nunes
That is more like a date / batch code, not a valve type. Its position and appearance are typical of a Brimar date and it decodes as week 4, May 1954 / 64, but would often be followed by a slash and another number that can be decoded to a valve type. But in any case, people can often identify the valve from its internal construction.
Lucien Nunes is offline
