24th Sep 2022, 10:25 pm | #1 |
RCA 24F650T (Thomson ITC-008 chassis) relay clicking/power cycling but no image
Hi All,
I've got a RCA 24F650T, that I've done a fair bit of work on, including dumping the EEPROM and installing a socket for the EEPROM, but recently I've got an issue which is baffling. So issue started with the TV refusing to power on, I will turn it on, it will click (I can hear the screen energize) and then it will flash white for a split second, and then turn off - upon which time it will restart. I've disassembled the screen and tried reprogramming the EEPROM with my known working .BIN with no avail. I did notice that if I remove the EEPROM completely and power up the TV, it will start in the menu with some random settings for a couple of seconds, upon which time it will shut off (and then go back into the same power cycle loop). I'm going to try to replace the EEPROM (a new one is coming in tomorrow), but I was also thinking if you had any ideas. I'm also planning on putting my oscilloscope on the I2C lines, in case the I2C lines are being pulled high/low somehow (though I'm not sure how). Is there anything on the analog side that you would recommend checking? I've attached the datasheet for the chassis, the visual inspection of the PCB looks pretty good, no obviously leaking capacitors. My particular TV has a separate PCB for the East-West drive, which I don't seem to have the schematics for. |
25th Sep 2022, 12:25 pm | #2 |
Re: RCA 24F650T (Thomson ITC-008 chassis) relay clicking/power cycling but no image
I am not a tv person but your mention of I2C lines reminded me of a long struggle with a Sony set. I didn’t have a scope at the time but managed to ascertain that the I2C was misbehaving but which of several chips could be responsible? Turned out to be a (spike protection ?) zener on the line which had gone partial short (3v ish rather than 5v6) leading to indeterminate logic states. Worth a check.
25th Sep 2022, 1:09 pm | #3 |
Not familiar with this model, but we did have problems with some of the late Thomsons that would trip the set if the CRT was tired and took too long to reach full emission.
25th Sep 2022, 11:40 pm | #4 | |
25th Sep 2022, 11:50 pm | #5 |
Thanks for the reply...yes that's certainly possible. The set has a lot of hours in it (it was my primary retro-gaming set), at least I feel less bad retiring it if that's in fact the reason
27th Sep 2022, 4:07 am | #6 |
I've fixed it! The fact that the TV works (for a little while) with no EEPROM installed gave me a big hint: so even though the I2C was working correctly when probed, I still had my suspicions since it seemed like a software/firmware issue. Upon further inspection, I found the following on the external "debug" connector, the 4 pin debug connector (which I had been using to tap the I2C bus) has cracked from the stress of being connected to an external device.
