12th Sep 2022, 7:23 pm | #21 |
Re: Loan of a ~1953 Pye Television in working order requested for Coronation ...
13th Sep 2022, 10:56 pm | #22 |
Hi.
I've not read this thread in depth TBH. My suggestion is to engage a competent restorer or TV engineer that has a Pye V4 or slightly older model, he should bring it and set it up and be on hand if there is any problem. You need a good knowledge of vintage TV and valves etc rather than trying to sort out an issue on your own. Signals can be terrestrial free view or via a dish and freesat with the receiver that has composite video and audio output . You then need an Aurora or Hedghog 625 to 405 line standard converter. There is another way that will work but very few here have tried this method, live streaming via the Internet is possible with a PC fitted with an ATI Radeon 2400 XT graphics card when programmed with the 405 line Modelines gives a 405 signal via a little patch circuit to a modulator to give the set the proper RF to the aerial socket of the TV. One thing to bear in mind is collector's don't like loaning sets out, this has been done in the past to the Broadcasters and they often are returned faulty or damaged. The set will run for hours, a set of its age, 70 at the time most likely, won't be wonderfully happy to run for 4 or more hours. I personally would only do it if I could oversee the whole thing. Best of luck with this.
13th Sep 2022, 11:15 pm | #23 | |
14th Sep 2022, 9:16 am | #24 |
Hi Kester,
all of the comments that have been made above are helpful , I am one of the television curators at the vintage wireless and television museum at Dulwich and would be prepared to help , I have sent you a private message regards Peter |
14th Sep 2022, 9:29 am | #25 |
I doubt that the Fellows would be satisfied with pretending to watch the Coronation on a 1953 set.
Surely there must be a Cambridge man in the 'hobby' who will take his gear over, just for the day? |
14th Sep 2022, 11:43 am | #26 |
Whatever arrangement is finally selected, I would suggest that a modern TV set should be available, connected, and ready for instant use as a standby in case of any fault or failure.
I would go so far as to select a 12 volt DC modern set, a well charged battery, and with a suitable aerial, so as to protect against almost any failure. The internet or data signal might fail, use the modern portable with direct off air reception. The equipment used to translate the modern digital signal into a suitable form for the vintage set might fail. The vintage TV might go wrong. The mains electricity supply might fail, hence a battery set. The Coronation will be of great importance, and it would be a great pity to miss it for want of a modern set as a spare. |
17th Sep 2022, 10:02 am | #27 |
Update:
To be clear: in correspondence with Crowthorne I am aware that I can procure a converter in a more conventional manner by Wednesday and the Royal Mail. That seems like a sensible longer term plan I should now follow -- (unless I were to go down the HackRF/HackTV route, which seems less popular and less well supported, but which has a number of features that I like and which I am therefore still investigating). But my post today is just attempting to find out if there is a friendly converter-owner who happens to be very close to Cambridge .(or between Cambridge and Norwich)... and who might not mind a visit this weekend -- so that I can attempt to succeed in an admittedly frivolous game I seem to have unexpectedly created for myself. Since today's post is in danger of getting very close to an "equipment wanted" one, I was in two minds about whether I should post in a different thread in the wanted forum. I hope my decision to repost to the end of this thread is acceptable. I don't want to abuse the forum's format or purposes. The fact that there is a "game" (of sorts) here, related to a national event, gives me perhaps some leeway, even if the game is one of my own creation! Best wishes. Christopher |
18th Sep 2022, 10:53 pm | #28 |
Am pleased to have got something working (see picture) so I can put this thread (and myself) to bed now. Thank you to all those who've helped me make progress here. Much more progress than I expected in so short a time. I look forward to seeing some of you again in events planned for the future.
18th Sep 2022, 11:01 pm | #29 |
Excellent result.
Your picture does show a 16:9 image letterboxed onto a 4:3 screen. This may be acceptable, but it may look better if you can zoom the image to fill the screen. This obviously involves discarding the left and right portions of the 16:9 image. Your ability to even do this will depend on your video source. |
19th Sep 2022, 12:04 pm | #30 |
Like the clock too.
