Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay). |
26th Feb 2024, 4:15 pm | #1 |
Class X2, Class Y Capacitors, and Snubber Networks
In a previous thread Which (UK) Class ? we were given a useful account of when and where to use Class X2, Class Y Capacitors, and Snubber Networks, but it seems a bit of a challenge to find where to buy the things. I've spent an hour trying to find a replacement for a Rifa X2 100nF which popped in a 70s stereo receiver, where it was wired across the primary of the mains tfmr using the full length of its axial leads. Unfortunately I started my search with CPC who have next to nothing. RS have a good range, but these components are not cheap and are on a long lead time so I ended up buying on eBay, where also there is next to nothing.
CPC only have two "class x2 suppression capacitors" which are in fact Rifa snubbers, 47nF with either 47 or 100 Ohms. They have 3 Vishay ceramic Class Y caps in 1, 2.2, or 4.7nF RS have X2 Class from Kemet and Vishay: KEMET PME271 series paper 250V ac with long leads: (1nF, 1.5nF, 2.2nF, 3.3nF, 33nF), 47nF stock No. 210-617 @ £1.80 ea in packs of 5, and most usefully 100nF stock No. 311-1074 @ £4.09 ea in packs of 5 Vishay F1772S series Polyester 310V ac are much cheaper but for long leads RS have only: 68nF stock No. 874-0793 @ £0.78 ea in packs of 10, and 470nF stock No. 874-0816 £2.05 ea in packs of 5 For Snubbers they have two "RC Network Capacitors". One is "RC Capacitor 100nF 120? Tolerance ±20% 250V ac" Stock No.672-7032 £2.48 ea "Our best size/performance series". The other is "XEB Surge Suppressor Unit 250 V Mains Protector" Stock No.672-7035, £3.90 ea - if you look at the datasheet you find it is 100nF + 120 Ohms, "Our best performance series" They also have Class Y series from both mfrs. I'd like to know what values are most useful for transient suppression at switch-on or switch-off? I hope this may be of use to others who need to replace these capacitor types. You can pull used axial X2 types from almost any scrap consumer unit with a switch-mode power supply, but these are invariably fitted on a PCB and the leads cropped off, making them useful only as replacements on SMPS, once you have checked that they haven't lost any of their capacitance.
- Julian It's good here |
26th Feb 2024, 4:38 pm | #2 |
Re: Class X2, Class Y Capacitors, and Snubber Networks
Cricklewood do them for 25p. Ok, it's best to buy a bit of stuff while you're on as it will offset the postage cost.
https://www.cricklewoodelectronics.c...apacitors.html
26th Feb 2024, 5:28 pm | #3 |
CPC have these https://cpc.farnell.com/epcos/b32922...vac/dp/CA07116 and also a Class X1 (440Vac) cap https://cpc.farnell.com/vishay/bfc23...40v/dp/CA06016
Regards, Symon |
26th Feb 2024, 7:27 pm | #4 |
Re CPC stock. There seems to be a problem with their search engine and quite often gives few results when infact there are others available.
If you do a global search for say 100nF X2 or 0.1uF X2 it only returns the four from Rifa. Doing a local search within Capacitors returns more possibilities. As well as those I linked in post #3, there are also these: https://cpc.farnell.com/vishay/bfc23...?st=0.1uF%20x2 and these: https://cpc.farnell.com/vishay/bfc23...?st=0.1uF%20x2 Regards, Symon |
26th Feb 2024, 10:25 pm | #5 |
RIFA PME series should be avoided as the paper plague. Just use MKT or MKP X and Y types.
27th Feb 2024, 11:16 am | #6 |
Maarten - I only want 20 years operation Won't a RIFA PME last that long?
Thanks for all the recommendations, but they are all for through-hole PCB mounting and won't reach across transformer terminals. Reichelt have a PHE820 type that might stretch. Maybe the PHE820 series is more reliable. I'm still puzzled about the range of values on offer: my failed item uses, like the DAC90 about 20 years earlier, 100nF, so why are we seeing values like 1nF and 4.7µF? Maybe large SMPS use that sort of value. I had been assuming that KEMET was a brand, but it looks more like a technology.
27th Feb 2024, 11:51 am | #7 |
Kemet (now part of Yageo) took over RIFA madness, not all of them are the bad types, the ones to avoid with metallized paper dielectric start with "PM" & "PZ", these crack & adsorb moisture, then burn up. We also had some go open circuit a few years ago at work, they were only 5 years old at the time.
The sooner Yageo/Kemet discontinue these the better, which is probably unlikely if people keep buying this rubbish, unfortunately Kemet even make a surface mount version starting with "SMP", there may be others in this new series to avoid. Also avoid Wima starting with "MP" these are also paper. I've used ceramic X/Y types, where I couldn't find plastic dielectric types with long leads, Murata & Vishay have ceramics with long leads. David Last edited by factory; 27th Feb 2024 at 12:03 pm. |
27th Feb 2024, 3:26 pm | #8 | ||
Also, leads can be extended.
27th Feb 2024, 3:58 pm | #9 |
27th Feb 2024, 5:27 pm | #10 |
I bought a Philips VR2220 portable V2000 recorder along with the companion VR2120 tuner unit last year. The latter certainly contans a RIFA metalised-paper 'smokebomb' capacitor which I will replace before applying mains.
But as the tuner/PSU is a separate unit, I guess it wouldn't do much damage to the tape path if it failed. |
27th Feb 2024, 5:42 pm | #11 |
Just extend the leads and if the joint offends you, just cover it with sleeving. Job done, 25p from Cricklewood.
27th Feb 2024, 8:32 pm | #12 | ||
Also, in those days the plastic cases might not have been very flame retardent (think of the K40 TV sets) so continuing to mount a capacitor that could possibly burn up, must have been a big no-no. Last edited by Maarten; 27th Feb 2024 at 8:45 pm. |
29th Feb 2024, 12:50 pm | #13 |
Agreed; I have added a pack (AKA a lifetime's supply) of the 310V X2 type suggested by Symon to my latest order from CPC
