Old 9th Feb 2020, 12:54 pm   #1
Michael Maurice
Michael Maurice's Avatar
Default Jvc hrj205
This machine is driving me round the bend.
When you switch on, the machine tries goes into eject mode even then there's no tape to eject.
It looks like the rec lock switch is used to detect when the machine is in the eject mode.
I've taken the mech apart and cleaned the mode switch.
It behaves normally if you remove the carriage and depress the cassette in switch.
I am really stuck so any help would be much appreciated. I'm repairing this on behalf of a good friend's dad.
Forum Moderator
Michael Maurice is offline
Old 9th Feb 2020, 10:56 pm   #2
Red to black
Red to black's Avatar
Default Re: Jvc hrj205
These machines suffered from EOT sensor problems as I am sure you well know, worth a look at this aspect.
Red to black is offline
Old 10th Feb 2020, 12:07 am   #3
McMurdo
McMurdo's Avatar
usual warnng about bench lighting triggering sensors!!
Kevin
McMurdo is offline
Old 11th Feb 2020, 4:29 pm   #4
Michael Maurice
I forgot all about the EOT sensors. Found end one dry jointed, resoldered and all is now ok.
Does anyone know of a brain surgeon, my memory needs updating!
Forum Moderator
Old 13th Feb 2020, 12:49 pm   #5
ben
ben's Avatar
Good on you for getting it going.
I have found this line of JVCs the worst ever. I have also had end sense problems and the mode switch is a constant source of trouble, giving rise to things like erratic /incomplete threading, eject problems, jamming in certain modes, tape chewing...you name it. The deck they used in the slightly earlier range (can`t recall the reference off hand) was far superior IMO.
Regards,
Ben.
ben is offline
Old 16th Feb 2020, 11:38 pm   #6
Michael Maurice
I cleaned the mode switch which on these decks is no mean feat as you have to remove the main cam, the pinch arm side plate and a few other bits, then re-align afterwards.
It seems that each new deck by any manufacturer is inferior to the one that preceded it.
Forum Moderator
Old 17th Feb 2020, 2:35 pm   #7
Maarten
Did the later JVC decks get better? Having seen this one, I always stayed away from them.
Maarten is offline
Old 17th Feb 2020, 9:58 pm   #8
Red to black
No! the next one was even worse IMO!
It wasn't as fiddly/fussy as the deck mentioned in the OP (it was quite a bit simpler), but had small plastic bits that held springs for the eject gear etc...etc. that snapped at random, often it was a game of guessing which plastic lug had snapped off, as more often than not it was not immediately obvious.
Even worse some critical spindles for crucial gears were not fixed to the main deck plate metal to metal as it were, but instead set into plastic inserts which predictably failed requiring a whole new deck plate, which necessitated swapping every bit from the old deck to the new! ie. a full strip and rebuild (jigsaw puzzle) including every spacer and washer and spring, with a full adjustment and set up to boot!.
JVC would only supply the bare deck plate as a replacement part, this was a fairly expensive item on its own, needless to say many were scrapped due to this.
