28th Aug 2021, 3:47 pm | #1 |
Homebrew guitar amp, speaker mismatch
I'm making a battery powered guitar amp out of some spare parts. I have the output/amp stage of a battery powered radio (Hacker Rp34 Democrat) which I am going to connect to a single speaker cabinet (Wharfdale Linton II). In the portable radio the amp normally powers a 15 ohm speaker, the Wharfdale is only 6 ohm, so there's a bit of a mismatch.
I have two 4 ohm/25w resistors that I can put in series between the amp and the speaker - 4+4+6 = 14ohms - and that should even things up. However, I want to have some sort of master volume in the form of an L-Pad. Would an 8ohm L-pad in conjunction with the two 4 ohm resistors work for the mismatch? Would the best configuration be from amp's output positive wire: 4ohm resistor - 4ohm resistor - L Pad input - L pad output - speaker? or L Pad input - L-pad output - 4ohm resistor - 4ohm resistor - speaker? or something else? Or should I use a (more expensive) 16ohm L-Pad - would that fix the mismatch? |
28th Aug 2021, 6:05 pm | #2 |
Re: Homebrew guitar amp, speaker mismatch
You will lose around half of your output with the resistors. And/ or pad. I think you will be fighting for gain as it is. So may need a preamp in front of the output amp.
It needs 2, 9v batteries and produces 1.25 watts for an input of 70 mv. Last edited by peter_sol; 28th Aug 2021 at 6:14 pm. |
28th Aug 2021, 7:20 pm | #3 |
A small matching transformer, turns ratio 1.41 to 1 would be a better bet
Ed |
28th Aug 2021, 9:30 pm | #4 |
And ( if you have not looked into the subject) look at speaker balance/phasing. it's where the cone of one speaker is goes forward, but the other one ( of a stereo pair) goes backward. Simple method is to connect a low voltage source to each and see which direction th cone moves.
29th Aug 2021, 4:36 pm | #5 | |
Yesterday I lashed it all together with just the resistors in series and the guitar came through loud and with an interesting distortion but the volume wavered oddly, with a sort of slow tremolo effect. It didn’t do this with the radio’s original 15ohm speaker, and the Linton cabinet didn’t do it when taking a feed from another battery guitar amp I have. Not sure why… |
29th Aug 2021, 4:37 pm | #6 | |
I really need something to attenuate the volume too, could I put an L-pad between this new transformer and the speaker? |
29th Aug 2021, 4:38 pm | #7 | |
29th Aug 2021, 5:56 pm | #8 |
1.5V is all you need, 9V might be too much for some speakers.
29th Aug 2021, 7:46 pm | #9 |
Hi Davy, transformer is far too puny I'm afraid
Ed |
30th Aug 2021, 2:15 pm | #10 |
I'm having difficulty finding a suitable audio impedance matching transformer that will allow an amp that normally has a load of 15ohms powering speakers of 6ohms. None of RS, Farnell or Mouser seem to sell anything with that step-down but I might just be misunderstanding how they are rated.
I might just go with an L-Pad. What would be the correct setup for 15 ohms amp connected to a 6ohm speaker - an 8ohm l-pad or a 16ohm l-pad? |
30th Aug 2021, 3:53 pm | #11 |
There is no real matching twixt amplifier and 'speaker here just the maximum current capability of the amplifier. This case 18V divided by two (peak to peak AC), 9V into 15 ohms, 600mA, older germanium transistors did voltage but not much current hence 18V and a high resistance 'speaker A 'speaker with a lower resistance will demand more current, 6 ohms would like 1.5A. Yor best bet would be two 8 ohm speakers in series, or a 9 ohm resistor (8 will do) in series
30th Aug 2021, 4:00 pm | #12 | |
Could I solve the mismatch by reducing the voltage into the amp down to 9v? (My buck booster can adjust down to this). |
30th Aug 2021, 6:30 pm | #13 | |
30th Aug 2021, 7:16 pm | #14 |
I'm making a guitar amplifier and it going all out some of the time - or all of the time - is exactly the sort of attribute I'd like to have available. I'm going to have a pot attenuating the input from the guitar, I also want a master volume on the speaker, so I need to figure out which L-pad (and possibly resistors) i need to have. Any ideas?
1st Sep 2021, 12:42 pm | #15 |
The woofer and tweeter inside the hifi speaker separately measure 7.6ohms and 13.4ohms (using a DMM). I'm guessing they are wired in parallel and along with the crossover unit inside result in the 6ohm load.
Would it be possible to fix the mismatch by wiring the woofer and tweeter in series for a 20ohm load (assuming a higher load is a better mismatch for the amp)? Can you wire a woofer and tweeter in series? |
1st Sep 2021, 6:13 pm | #16 |
My suggestion would be to use an 8 ohm L-pad for example:-
https://cpc.farnell.com/monacor/lp-1...543?st=l%20pad Which costs £6 plus postage. A brief data sheet is avalable at that page. This presents a (relatively) constant 8 ohms to the driving source - assuming an 8 ohm speaker is connected. To keep your amplifier happy you will need to add the 8 ohm resistor between the amplifier and the L-pad so that it always sees about 16 ohms. As mentioned earlier this will lose you half the power output but would work until you upgrade the amplifier (to lower impedance output) or locate a suitable transformer. I would not attempt to series connect a tweeter and woofer.
George |
1st Sep 2021, 10:22 pm | #17 | |
Having lashed up the amp and hifi speaker I reckon something's up with the crossover. Both woofer and tweeter responded to a 1.5v battery check but playing the guitar through it the lower/bassier strings ring loudly but the higher/treble strings hardly make a noise. Have got some replacement capacitors on the way, along with the L-pad. |
1st Sep 2021, 10:30 pm | #18 |
The low frequencies can damage tweeters.
The tweeter won't last long if you wire it in series with the woofer. |
2nd Sep 2021, 10:02 am | #19 |
I'm probably not going to go down this route but I've read on a few hifi forums that wiring them in series is possible with a capacitor (2.2uf?) in series with the tweeter.
2nd Sep 2021, 11:04 am | #20 |
