Old 21st Feb 2020, 4:05 pm   #1
Norman Raeburn
Default Valve identity help
I have this valve in my collection which has no identifiable numbers. Could it be a PX4? Is there any way to positively identify it. I will await answers from the experts. Many thanks, Norman
ID:	199457   Click image for larger version
Norman Raeburn is offline
Old 21st Feb 2020, 4:09 pm   #2
Ampmatt
Default Re: Valve identity help
Definitely a PX4
Ampmatt is offline
Old 21st Feb 2020, 4:11 pm   #3
barrymagrec
Looks like a PX4 to me - you could check the heater resistance but you would need to know what it should be, cold, which will be quite low.
barrymagrec is offline
Old 21st Feb 2020, 4:40 pm   #4
paulsherwin
paulsherwin's Avatar
It certainly looks like a PX4 - nice condition too.
paulsherwin is offline
Old 21st Feb 2020, 4:42 pm   #5
GrimJosef
Another way to come at it is to ask what it might be if it's not a PX4. I don't think there are very many alternatives are there ?
Cheers,
GJ
http://www.ampregen.com
GrimJosef is offline
Old 21st Feb 2020, 6:05 pm   #6
PJL
The markings will probably be on the opposite side to the label.
PJL is offline
Old 21st Feb 2020, 7:04 pm   #7
Herald1360
Herald1360's Avatar
Stick 4V on the filament pins (start with 2V just in case....)* and see what lights up. Hopefully it will be all of the filament though even if it's only half it could still be used to breathe lower powered life into an old radio.
* Remember the AC042!
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 21st Feb 2020, 8:26 pm   #8
greg_simons
greg_simons's Avatar
Deff px4, you could try shining the light from an led torch on the glass envelope, it can sometimes pick out the faded numbers.
Greg.
Picture, sound?, DOOR.
greg_simons is offline
Old 21st Feb 2020, 8:39 pm   #9
Norman Raeburn
I have tried shining a light on it and also tried a uv light source but can’t see anything. I will have another look tomorrow. Norman
Old 21st Feb 2020, 9:37 pm   #10
Radio Wrangler
Radio Wrangler's Avatar
I think the only options are to try the filament as Chris says, then find an old enough radio to try it out in.
If you loaned it to an audio aficionado to try out and see if they recognised it by rhythm/pace/authority/granularity and speed of bass, you'd never get it back off them.
It's got to be a triode with that number of pins.... did any half-wave rectifiers look similar?
Radio Wrangler is online now
Old 21st Feb 2020, 10:14 pm   #11
TowerRadio
With the valve fairly cold breath on it ,may reveal a faint ID.Les
TowerRadio is offline
Old 22nd Feb 2020, 8:03 am   #12
snowman_al
snowman_al's Avatar
Well it could be a PX25 of course...
You will have to measure the filament current to know. A PX4 draws 1 Amp at 4 volts, the PX25 draws 2 Amps. Either way a nice valve to have.
Never Leave Well Enough Alone...
snowman_al is offline
Old 22nd Feb 2020, 10:16 am   #13
barrymagrec
PX25s are significantly taller....
Old 27th Feb 2020, 7:52 pm   #14
whiskas
whiskas's Avatar
I also think it's a PX4
...where on earth did that spring/screw go??
whiskas is offline
Old 27th Feb 2020, 7:57 pm   #15
Norman Raeburn
I am fairly sure it’s a PX4, with 4v heater it draws about 950ma. I have a Taylor valve tester and will give it a go and see how it tests. I will report back with the results. Norman
Old 11th Mar 2020, 6:17 pm   #16
Norman Raeburn
Hi Folks, To bring this to a conclusion and after repairing my valve tester I have the following results. I don't know how well valve testers compare to book figures.
I have the following result, PX4 mutual conductance reads 4, book states 3.5
I also have a PX25 mutual conductance reads 1.5, book states 4. Is this likely to be duff or is it a case of it may work ok in something. Looking forward to your opinions please. Norman
Old 11th Mar 2020, 6:56 pm   #17
Herald1360
Herald1360's Avatar
Sounds like a good PX4
And a tired PX25
The PX25 will probably still work to some extent in a single ended application and look the part at least.
....__________
