21st Dec 2011, 4:12 pm | #1 |
Beolit 707
I have a dark beige (curry colour) Beolit 707 and the grilles/panels are quite dirty with ingrained grime. Has anyone of the forum members ever cleaned one of these successfully?
I'm sure washing powder would do the trick but I don't want to cause any damage. Any advice is appreciated. Thanks. |
21st Dec 2011, 5:25 pm | #2 |
Re: Beolit 707
Hi Steve
I assume that these are plastic, if so I have found generic Foam cleaner from CPC/Farnell to be excellent. Failing that warm to hot soapy/detergent water and a soft brush/toothbrush. John Caswell |
22nd Dec 2011, 8:54 am | #3 |
Re: Beolit 707
I have one the same colour that had spent some years in a kitchen and had got somewhat 'sticky'. A good scrub with a stiff toothbrush in hot water and Fairy Liquid got rid of most of the muck, but the surface texture held on to some of grime and it wouldn't come off. I suspect anything stronger or a solvent might damage the texture. It's rather an odd finish.
Regards, Richard, BVWS member |
22nd Dec 2011, 5:55 pm | #4 |
Re: Beolit 707
Thanks John, thanks Dickie.
Tried both your methods with a little soak in Daz and it's as good as new. The shade has lightened ever so slightly and the water turned light brown. I thought I'd loosened the colour but I think the staining may have been years of nicotine. Thanks for your help. |
