Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval. |
21st Nov 2023, 2:58 pm | #1 |
Location: Burntwood, Staffordshire, UK or Kabaty in Warsaw Poland.
Connection not secure message
Every time I access the site I get this message.
I usually just press continue to site regardless without any problems. |
21st Nov 2023, 3:22 pm | #2 |
Re: Connection not secure message
Check your computer's time and date are set correctly.
What URL are you using to access the forum? Please copy it from the address bar and post it here. Do you get the error if you click on this link? https://www.vintage-radio.net/forum/ |
21st Nov 2023, 3:46 pm | #3 |
Hi Paul
Time and date are correct This is the URL https://www.vintage-radio.net/forum/ I don't get the error using your link Just to add that occasionally I don't get the error message, but most time I do. This is my works PC. Mark |
21st Nov 2023, 4:30 pm | #4 |
You probably have a bookmark saved which is using the old unencrypted URL, http://www.vintage-radio.net/forum/. This should automatically redirect to https://www.vintage-radio.net/forum/ but in some cases this will trigger the security warning you're seeing.
Edit your bookmark, changing 'http' to 'https', and the problem should go away. |
21st Nov 2023, 6:56 pm | #5 |
Pilot's bookmark already is set for the https:... version? (Post #3).
21st Nov 2023, 7:07 pm | #6 |
No, that's the URL that he's seeing after accessing the forum and the http->https redirect has taken place. If he checks his bookmark he'll see it's incorrect.
22nd Nov 2023, 12:39 pm | #7 |
All is well now thanks.
