1st Apr 2020, 6:22 pm | #21 |
Re: How do I get this wheel off my radio tuner
There is another common variation on those which also marketed as a car battery terminal puller, example here:-
https://www.amazon.co.uk/dp/B07GB126RM While that one would also have potential uses for pulling flywheels etc off, it has a rather broad end which would probably put pressure on the flywheel rather than on the shaft. But it could find uses elsewhere in our hobby. |
2nd Apr 2020, 11:08 am | #22 | |
At the moment the wheel is stopping the back plate moving backwards. If I remove it the back plate will move a little further back as the hole the shaft runs through is a bit oversize. That will allow a little more access. If I wanted to get the back plate off completely there is no way without removing the wheel. |
3rd Apr 2020, 1:54 pm | #23 |
Ah! now I understand thank's for clarifying it , did you manage to remove the flywheel yet? Mick.
