Old 18th Aug 2016, 9:21 am   #41
Radio Tech
Radio Tech's Avatar
Default Ekco PB179 Dial
Hi folks,
Not sure if this is the right place but attached is a picture of the dial for the Ekco PB179, I seemed to remember that another member was looking for something like this. Hope it helps.
Ken
Name:	parts of Ekco 003.jpg
Radio Tech is offline   Reply With Quote
Old 1st Nov 2016, 9:36 am   #42
derek.ireland
derek.ireland's Avatar
Default Re: Useful tuning scale and label scans etc
Re Marconi CR300 dial. Thanks for dial printout Lawrence.
This may be of help to someone not having a colour printer, only black. I printed the dial on Southworth parchment paper gold which I found to be the same colour as my dial. Went over the intermediate lines with a black pen then three fine coats of varnish. Job done, impossible to tell the difference. Now going to have a lay down just recorded both drives?
Thanks again, Derek.
derek.ireland is offline   Reply With Quote
Old 1st Nov 2016, 9:41 am   #43
I uploaded that yonks ago, never thought it would get used after all this time, glad you found it useful.
ms660 is offline   Reply With Quote
Old 1st Feb 2017, 10:09 am   #44
Nymrod121
Nymrod121's Avatar
'Philips' logo scanned from a valve table radio & MS Paintbrush-edited to remove minor scuffs/scratches.
Guy
Name:	Philips logo_table radio.jpg
Nymrod121 is offline   Reply With Quote
Old 4th Feb 2017, 8:30 pm   #45
Panrock
Panrock's Avatar
Bush TV22 label set.
Steve
https://www.radiocraft.co.uk
Panrock is offline   Reply With Quote
Old 4th Feb 2017, 8:34 pm   #46
Panrock
Panrock's Avatar
Philips 634A "drawer" (often missing).
Steve
Old 11th Sep 2017, 7:48 am   #47
FIXITNOW
FIXITNOW's Avatar
Default Re: Hacker Mini-Herald RP17 Front
scanned it this morning
will at some stage do a touched up version
have a higher res version 600dpi if needed as due to site limit this is 300dpi one
FIXITNOW is offline   Reply With Quote
Old 11th Sep 2018, 4:33 pm   #48
terrykc
I've had a go at touching it up and it has come out well, I think (but, of course, I'm prejudiced!)
I've assumed that the original was black to the edges and that the paint has come off where it was fixed and will be invisible anyway.
Personally, I think it would look better with the text at the bottom and the Volume and Tuning legends removed but other might disagree.
The problem is not only identifying the exact font used (and hoping it is widely available) but also that the scan is twisted. I've improved on the original but can only adjust it in 1 degree intervals so you will notice it now tilts the other way (but not so much!)
Unless someone can suggest a way of producing text with a matching tilt, I think it would look terrible, although it might be possible to carefully adjust the position of each character to match the tilt!
I've previewed this picture and it looks OK but I do have the original which is a much bigger file that I could insert in a pdf if anybody is interested.
Name:	Hacker-RP17 scale.jpg
terrykc is offline   Reply With Quote
Old 13th Sep 2018, 11:02 am   #49
Nymrod121
Nymrod121's Avatar
Some additional tweaks (and thanks for your original file, Terry )
(Mods, any chance of having my post #50 deleted being as it's superfluous now? - thanks)
Name:	Hacker-RP17 scale_v03.jpg
Last edited by Nymrod121; 13th Sep 2018 at 11:04 am. Reason: request re #50 deletion
Old 16th Nov 2018, 3:11 pm   #50
PJC58-Hythe
PJC58-Hythe's Avatar
Another couple for the collection - Grundig 2043 and Marconi T18DA
Peter - M0HYT - BVWS Member - GQRP Club
http://www.retroworkshop.co.uk
PJC58-Hythe is offline   Reply With Quote
Old 16th Nov 2018, 3:14 pm   #51
PJC58-Hythe
EKCO ACT96 Dial artwork
Old 26th Apr 2020, 9:50 pm   #52
kestrelmusic
kestrelmusic's Avatar
Defiant MSH546
I'm working on this and it needed a completely new dial. The vertical line at the top appears on the original, presumably it's an alignment marker.
Name:	Defiant MSH546 Dial.jpg
kestrelmusic is offline   Reply With Quote
Old 1st Jul 2020, 1:21 pm   #53
cathoderay57
Attached is an image for the curved dial station name panel for a Murphy A50. Two versions are provided - one in MS Word 2007 in which the doc contains a 2-column table with just the centre vertical border line enabled. The left-hand column is blank. Also a version in pdf. Both documents have been sized to print correctly as actual size, but ensure in your printer set-up that no check-boxes such as "fit to page" have been left ticked.
cathoderay57 is offline   Reply With Quote
Old 1st Jul 2020, 2:01 pm   #54
cathoderay57
When printing onto a transparency for application to a glass or plastic panel the dial image needs to be reverse printed or flipped. Flipping the image for reverse printing is easy when you know how! I did struggle for a bit. The easiest way is from printer set-up. For example I have a Canon TS5051 inkjet. To print in reverse from MS Word select print, printer properties, media type drop down needs to be changed from plain paper to other papers > T-shirt transfers. Can also be described as mirror image print. If you get stuck best Google your printer name with the question.
Old 3rd Oct 2020, 10:14 am   #55
ajgriff
ajgriff's Avatar
Wireless for the Blind (BWBF) Decal/Transfer
The attached image represents my attempt to recreate the BWBF decal/transfer most often seen (partially worn away) on red Roberts R505s. The PDF contains a high resolution printable version of the appropriate size. Hopefully this will be of use to one or two people other than me.
My thanks are due to John (stitch1) who, via the forum, originally provided the photo' upon which the reconstruction is largely based.
Alan
Name:	BWBF Decal.jpg
ajgriff is offline   Reply With Quote
Old 4th Oct 2020, 10:08 am   #56
ajgriff
ajgriff's Avatar
Wireless for the Blind (BWBF) Decal/Transfer - Previous Post #56
After posting I noticed that in the conversion to PDF format the decal had been clipped slightly at the right hand edge. I've increased the size of the white background to obviate the problem and a revised file is attached. The size of the decal itself remains unaltered. My apologies for not noticing the error before posting the file.
Alan
Old 6th Jul 2021, 4:03 pm   #57
Tuning scale windows for the Hallicrafters SX24 receiver.
Name:	SX24 TUNING.jpg
ID:	237202   Click image for larger version
Name:	SX24 BANDSPREAD.jpg
Old 23rd Jan 2022, 4:10 pm   #58
Alistair D
Alistair D's Avatar
Heathkit IM-28
I recently sent the scale plate from my scrap meter to another forum member to replace his faded one. Alas it now seems to have got lost in the post. Luckily I had the forethought to do a high res scan of it before posting so all is not lost.
I also have the file as a .png so if anyone wants that PM me an email address and I will send it on.
Al
I won't tell you how I discovered that.
Alistair D is offline   Reply With Quote
Old 22nd Feb 2022, 1:53 pm   #59
Top Cap
Top Cap's Avatar
B28/CR100 scales. I have just updated my pdf for these receivers and included an enlarged section that dealt with making a new roller scale.
However, I also saved a MS Word document which hopefully will preserve the definition better and make transfer to an art program such as PS Paint a lot easier.
It is too big to load here but available here:-
http://www.g4cnh.com/public/CR100_Reno_notes.doc
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way!
Top Cap is offline   Reply With Quote
Old 22nd Feb 2022, 1:54 pm   #60
cathoderay57
Final versions of Murphy A48 dial legends in forward and reverse print attached.
Last edited by Cobaltblue; 23rd Feb 2022 at 10:32 am. Reason: Previous draft post removed, request removed :)
