12th May 2021, 4:43 pm | #1 |
Wyndsor Viscount
I've just bought a Wyndsor Viscount tape recorder and wonder if anyone knew a source of information on it.
It's a mono, valved, machine using the Collaro Mk 4 (I think) deck, I have the information from 'up top' on the deck. Three speeds (3.75, 7.5, 15 ips), 4 heads (erase and combined record/play for each direction). Alas the speaker in the lid is missing (I have the lid, fortunately), along with its cable which I assume plugs into the 2 pin socket on the back of the machine, looks to be similar to an LT battery plug and I probably have one somewhere. I've worked out how to get inside -- take off the plastic deck plate, then remove the wooden strip at the top front of the case (2 obvious screws), remove the EM84, then take out the 3 screws retaining the deck and the whole lot lifts out. But before I do any more, does anyone have a circuit diagram, etc? |
12th May 2021, 8:55 pm | #2 |
Re: Wyndsor Viscount
Circuit diagram is attached. Original scan quality is quite good, but Forum attachment process has reduced the quality.
PM me with your email address if you want original copy of the scan. David |
13th May 2021, 7:47 am | #3 |
Wyndsor was founded by Robert Creek (his son later formed Creek radio). Bob was ex RAF so most of his later models were named after RAF aeroplanes; they did a lot of secret government work.
Originally radio and amplifier makers they used Lane, Collaro, BSR and other (Truvox, Harting...) decks. The Viscount was available with a high/low speed converter offering up to 15ips. |
13th May 2021, 11:38 am | #4 |
Thanks.
The model I have is called a Trident, so it looks like names of civilian aircraft were used too. https://www.vintage-radio.net/forum/...d.php?t=157411
13th May 2021, 12:26 pm | #5 |
Indeed, Wyndsor did use other aeroplane names (Vanguard, Sabre...) and non-aviation (International, Dauphin...). Wyndsor was a play on Windsor (the castle and a royal Herald formed their early motif).
14th May 2021, 2:27 pm | #6 |
Hellyer's "Tape Recorder Servicing Manual" book has schematics for the Dauphin, Herald, Regent, Victor & Viscount but not the Trident.
David |
15th May 2021, 12:02 pm | #7 |
Reasonable quality PDF for the Viscount schematic is attached.
Even though saved in correct orientation it may open upside down. David |
16th May 2021, 5:57 pm | #8 |
Note in the "A guide to British tape recorders" indicates that the Herald referenced in Hellyer's may have been a typo for the Wyndsor Heron.
