Old 8th May 2021, 9:33 pm   #1
Trevor Leese
Default Sony TC266
Hi everyone, can anyone offer some words of advice please
I have a Sony TC266, when i put it in to rewind the latch does not latch, i have to hold it in rewind position.
Thank you.
Trevor
ID:	233612   Click image for larger version
Trevor Leese is offline
Old 8th May 2021, 9:42 pm   #2
Restoration73
Restoration73's Avatar
Default Re: Sony TC266
You need to load a tape, there is a small sensor arm to the left of the erase head. If you
push it in to simulate a tape, then the control will lock in.
Restoration73 is offline
Old 9th May 2021, 8:24 am   #3
Trevor Leese
Hi, i have pushed the auto stop wire up and put the control knob into rewind but it does not latch, any idea's as to what to do next please.
Trev.
Old 9th May 2021, 8:54 am   #4
DMcMahon
DMcMahon's Avatar
Quite possibly similar issue to your TC366 Fast Forward issue due to the horrible Play/RWD/FFD selector switch mechanism where Play, FFD and RWD can be very difficult to stay latched due to mechanical set-up as referenced below. I hate working on that assembly and getting it in and out of the machine.
https://www.vintage-radio.net/forum/...ighlight=tc366
DMcMahon is offline
Old 9th May 2021, 10:55 am   #5
Nickthedentist
Nickthedentist's Avatar
...but they're lovely machines when you've got them working
Nickthedentist is online now
Old 9th May 2021, 3:28 pm   #6
DMcMahon
DMcMahon's Avatar
Yes agreed
DMcMahon is offline
Old 10th May 2021, 5:49 pm   #7
Trevor Leese
thanks everyone for your input its very much appreciated. cheers
Old 10th May 2021, 6:20 pm   #8
DMcMahon
DMcMahon's Avatar
Had a quick look at one of my TC-399 assemblies that is off the machine, to remind me how the latching is achieved.
The main latching in all 3 modes is done by the upper and lower auto shut off levers.
First photo shows upper lever latched in Rewind and the second photo shows the lower lever latched in Rewind.
Correct latching operation of both levers is dependent upon the "Screw B" adjustment (and also maybe by the "Screws A" adjustment ) as referenced in linked Thread above and detailed in the Service manual.
Would recommend trying to adjust Screw B adjustment first to see if can get Rewind to latch and still latch Play and Fast Forward.
If no good then I think the assembly should be removed (not overly easy) and check the levers are not gummed up by old dried grease and the springs are OK. Also make sure that roller arm is dropping into the cam assembly OK at all positions.
ID:	233724   Click image for larger version
DMcMahon is offline
Old 10th May 2021, 6:42 pm   #9
vidjoman
Could just be that it’s sticky grease and needs cleaning.
vidjoman is offline
Old 11th May 2021, 2:00 pm   #10
Trevor Leese
I had the mechanism stripped down and degreased but still no avail, but the roller showing in davids photo looks a possibility, I'll check it out.
Thanks guys.
