Old 5th May 2021, 12:30 am   #1
Michael Maurice
Michael Maurice's Avatar
Default Teac X1000R
Does anyone know the diameter of the capstan belt in these recorders?
It seems near impossible to get them from Germany and it takes too long to get them from the US.
Forum Moderator
Michael Maurice is offline
Old 5th May 2021, 4:20 am   #2
dmaillard
dmaillard's Avatar
Default Re: Teac X1000R
The PRB database lists it as a FR16.9 part, so 16.9” in circumference.
dmaillard is offline
Old 5th May 2021, 11:48 am   #3
Michael Maurice
Thank you
Forum Moderator
Old 5th May 2021, 12:12 pm   #4
TIMTAPE
Originally Posted by dmaillard View Post
I havent seen this list of belt dimensions for such a wide variety of decks. A great resource. Thanks!
TIMTAPE is offline
Old 5th May 2021, 12:58 pm   #5
DMcMahon
DMcMahon's Avatar
I also have not seen this, it is very interesting and useful.
DMcMahon is online now
Old 6th May 2021, 12:18 am   #6
dmaillard
dmaillard's Avatar
For those who are interested here is the link to the PRB database,
http://russellind.com/client/download/PRB_Belt_XRef.pdf
Unfortunately the database was last updated in 2006, but this should suffice for the majority of vintage audio gear with belts.
Old 6th May 2021, 9:02 am   #7
Lucien Nunes
I have had issues with non-original capstan belts for X-decks in the past, not running true or being slightly off size. If you find a source of belts that are accurate and trustworthy, it would be good to know. I suppose any issues with belts are increasingly going to be overshadowed by issues with the capstan motors though, as evidenced by the increasingly silly prices being asked even for the 7W motors.
Lucien Nunes is offline
Old 6th May 2021, 10:43 am   #8
Ted Kendall
So have I. If memory serves, the 1000 and 1000R belts are slightly different, as the belt has to ride onto different drive surfaces as the motor is reversed. I was able to get OE components when I was working n two of these nachines a while ago, but I don't know the present situation.
Ted Kendall is offline
Old 6th May 2021, 11:07 am   #9
Lucien Nunes
Yes, and as I recall I ended up using belts from a supplier in the US, that were supposed to be for the reversing deck, on a single-direction model as they were closer to that spec and would not behave on the R. I would not have taken as deep an interest had a nearly-new X-1000 not been my first reasonable recorder when I was 14, that turned in some eminently satisfactory results while I was learning to record. It was something of a disappointment, when I first opened it up, to discover the distinctly lightweight capstan drive setup that lay within.
Old 6th May 2021, 2:00 pm   #10
TIMTAPE
That admittedly small DC motor is in a number of Teac decks. Perhaps the best way to destroy it is playing sticky shed tapes. I've had some success repairing motors that weren't too damaged from overloading. When removing and refitting the motor it's important to retain all washers in their original positions, at least on reversing models.
TIMTAPE is offline
Old 9th May 2021, 2:22 am   #11
quiberon
Sam, "Skywavebe", over on Tapeheads, recommends 16.8" circumference belts for the X-1000R.
quiberon is offline
