28th Mar 2021, 7:29 pm | #21 |
Re: 50's car radio info. Smith and Sons 200x.
paul...they are all duff !!
28th Mar 2021, 7:34 pm | #22 |
Transformer burn-up can also be caused by a stalled vibrator... probably allied with too large a fuse. A burned smell is a bit of a give away. That unit needs a good going through of the capacitors and a solid state vibrator replacement as well as the transformer redoing.
Hopefully the head unit won't be such heavy going. David
28th Mar 2021, 8:18 pm | #23 |
thanks for the replies ,keep them coming, i have opened a whole new learning curve for myself with this radio and have been going through past post's, way over my head, old dog new tricks etc.
has anyone used the royal signals vibrator or any other in a repair, i could use with a re wound xformer. |
28th Mar 2021, 8:20 pm | #24 |
You could also think about adding an "Aux" input - see the notes at the top of this section of the forum.
Edit When I restored one the only source of vibrators I could find were in America so I used the original. That site is interesting - I might suggest that he gets one. I hadn't thought that a stuck one could blow the transformer, but of course it could.
Paul |
28th Mar 2021, 9:10 pm | #25 |
Many vibrators are - these days - becoming problematic. The chopper-and-solenoid-coil assembly was generally mounted on somewhat-flexible 'leads' from the base, and the top of the assembly was fitted into a kind-of reverse-top-hat thing made of foam-rubber to support it from the outer metal case.
Problem: the foam-rubber was vulcanised using Sulphur. Over the decades as the rubber decayed it released sulphur-dioxide - which combines with any moisture to become sulphuric-acid! SO2 and H2O ----->>>>> H2SO4 This then attacks the contacts and the coil-winding of the chopper-assembly. The rubber also crumbles to dust. Any 50+ year old vibrator is likely to be problematic - if the contacts weld themselves in one position it can easily melt the transformer. So don't risk spending money getting the transformer rewound only to cook it again because your vibrator is suffering senile-dementia. |
28th Mar 2021, 11:53 pm | #26 | |
Found one..... https://www.radiomuseum.org/r/radiomobil_20x20.html
29th Mar 2021, 3:10 am | #27 | |
Sulphurous acid is a much weaker acid chemically, and while it may well attack bits of the vibrator it shouldn't be as nasty as sulphuric acid. |
29th Mar 2021, 7:51 am | #28 |
I am going to open up the vibrator this morning and have a look, I have been searching for replacement ideas.
29th Mar 2021, 8:04 am | #29 |
The rubber inside these vibrators is "Sorbo Rubber" has a very distinct smell.
Although it's possible to get these vibrators working and if your keeping this radio for your own use that's a good thing, If I were passing it on to someone else I think I would fit a solid state replacement for long term reliability. Graham did a great piece of work here: https://www.vintage-radio.net/forum/...ad.php?t=41944 Hope that helps. Cheers Mike T
29th Mar 2021, 3:47 pm | #30 |
hi, Graham...just spent 2hrs going through the post's in the ssv thread (yep know what that means now),that is a hell of a great read !! way over my head.
But understanding improved. so what to do, build one or buy the one advertised as a straight replacement for the plessey 1214. Ed, i will be contacting you for the sorting out of the transformer rewind. getting capacitors and deciding on the vibrator, got a lot on at the moment so may buy one ready to fit. Rob. |
29th Mar 2021, 4:51 pm | #31 |
Personally I would buy a ready made one if the cost isn't too much of an issue. They are fairly expensive but they are ready to go.
Paul |
30th Mar 2021, 6:10 pm | #32 |
Power unit looks bad only found one capacitor that seems OK and that's the coupler that I would change anyway. Can anyone suggest why the capacitor (I think) is connected from pin 3 (vib) to ground, it's not on my schematic?
The Hunts cap I think is C109. Moderator should I start another thread for the repair? |
6th Apr 2021, 1:45 pm | #33 |
No need for a new thread.
6th Apr 2021, 2:53 pm | #34 |
Re: 50's car radio repair. Smith and Sons 200X.
Could it be some sort of interference suppressor? Possibly fitted at a later date?
Paul |
7th Apr 2021, 12:00 am | #35 |
I've got one of these somewhere. It looks like someone connected yours up to a supply and sat there waiting for it to do something, not realising that you had to hear a 'buzzing' sound, when the magic smoke was suddenly released, probably quite recently, as this tends to be what folk do. I'm guessing you've got the interconnecting cable for the two units, although you don't show it in your pictures - mine is missing, so I was going to have to make something up, hence why it got buried in the "round to it one day, if ever" pile.
I've found some pictures on file from when I last looked at it some four years ago and three of them are posted below for comparison and reference. I think you've got your work cut out with that one of yours (as I will have with mine, no doubt - if I ever bother with it) and it won't be a cheap repair with major components needing replacement/repair. I think there was also an HMV version of the same radio. Lastly, I would strongly advise running it from a bench power supply, preferably current limited - don't use a 12 volt car battery, as there's hundreds of amps available and you may have a flash and a bang if/when something goes wrong! Anyway, good luck with your quest to fix it...you may spur me on to look at mine again - pictures of the innards of mine for reference to yours below:- |
7th Apr 2021, 10:39 am | #36 |
If you can get hold of one an old desktop PC power supply makes a good 12v (and other voltages) supply
Paul |
7th Apr 2021, 7:53 pm | #37 |
I have sent off the transformer for rewind, replacement caps and SSV have arrived, I have the connecting cable and my friendly garage owner donated an old 12V battery, so guess I am doing this and will make a start on the power supply when the transformer arrives.
Being a novice at this I was thinking of the best way to test it, would I be correct in thinking I could feed it with an audio signal, with a speaker connected. Much the same as I do through the PU input to a radio. |
7th Apr 2021, 9:02 pm | #38 | |
I wouldn't use a car battery, it's dangerous, especially if you're a novice! If you must use it then make sure you've got an appropriate fuse in line. The idea of an old computer power supply with the appropriate connections linked out on the multiplug to make it fire up is an excellent idea - as mentioned by PaulR above. I've used an old CB radio power supply in the past for powering this sort of thing, and being 13.8 volts are ideal to replicate a 12 volt battery being charged by a car dynamo, which would be the normal working conditions of the radio, but always ensure there's an in-line fuse regardless. I've used a car battery in the house in the distant past to test large linear amplifiers, but it's not to be recommended! Last edited by Techman; 7th Apr 2021 at 9:07 pm. |
7th Apr 2021, 9:27 pm | #39 |
A quick ebay search shows many second hand ATX power supplies quite cheaply. Useful for future projects!
Paul |
8th Apr 2021, 4:58 pm | #40 |
Hi, thanks for the advice, when I say novice I mean at repairing old radios, not in electrical engineering, all the equipment I worked on was battery powered one way or another, up to 200 VDC and plenty of amps as well, so I will be OK using a fused battery supply in my shed. I have a old Leak tuner that I was thinking to use to prove the power supply was good before trying the Smiths radio, does that seem reasonable?
