Old 1st Mar 2021, 9:18 pm   #1
Mrrnoname
Default Sony TC-377 Parts Help
Hi All,
I've come across a Sony TC-377 tape deck which is cosmetically in superb condition.
I am familiar with these decks and have serviced them before. It looks as if someone was part way through servicing the unit when it was abandoned for whatever reason. All parts are there except for the following (you guessed it)...
Motor Pulley
Rubber idler wheel that goes between the pulley and flywheel.
I've looked everywhere for these parts online but they seem to be near impossible to obtain. Nobody seems to sell reconditioned, second hand or even reproductions!
Can anyone offer any advice or help before I look in to purchasing another deck as spares (seems a waste to do that for just two parts!)
Regards,
Max.
Mrrnoname is offline
Old 2nd Mar 2021, 10:31 am   #2
TIMTAPE
Default Re: Sony TC-377 Parts Help
Hi Max, that's a shame. The TC 366 had the same mechanicals I think, and maybe some other Sony models of that era. Maybe the TC 399. Others here will probably know.
TIMTAPE is offline
Old 2nd Mar 2021, 5:14 pm   #3
DMcMahon
DMcMahon's Avatar
Very similar on the TC-399.
The motor pulley is the same base number 3-518-067, there are 7 fine speed variants of this for 50Hz and another 7 different part number variants for 60Hz.
On the 399 the pulley sits on top of a Table Ass'y, motor pulley holding X-3472-029-0 but I cannot easily see this part in the 377 manual.
The 399 manual says to test speed using a test tape and then fit appropriate motor pulley to get correct playback frequency ! cannot see this test in the 377 manual.
The idler (assuming it is Idler B, driving) has same number 3-472-152-0 but there is a slight difference in Idler Tire part number 3-472-155-0 for the 399 and 3-472-155-01 for the 377.
DMcMahon is offline
Old 2nd Mar 2021, 6:12 pm   #4
ms660
ms660's Avatar
So far as I can make out the capstan idler is the same part number for the TC-266, TC-366, TC-377, TC-399.
The motor pulley is the same part number for the TC-266, TC-366 but that part number is different to the part number for the pulley for the TC-377, TC-399, the part number for the pulley for the TC-377, TC-399 are the same.
Part of the adjustments for the TC-377 are missing in the online manuals I've seen because the relevant pages are missing.
Lawrence.
ms660 is offline
Old 2nd Mar 2021, 8:27 pm   #5
DMcMahon
DMcMahon's Avatar
The idler that drives the flywheel has slightly different numbers, X-3472-033-0 for the 399 and X-34720-33-0 for the 377, same numbers but slightly diferent format so probably actually the same.
The previous "Idler B, driving" 3-472-152-0, I referenced drives the Supply table in Rewind.
DMcMahon is offline
Old 2nd Mar 2021, 8:41 pm   #6
ms660
ms660's Avatar
It will mean the same for the flywheel idler, Sony also used to change some part numbers that were listed in the original manuals, we were sometimes notified with amendment sheets to the manuals or when ordered with the original number a note would come with the part ordered to the effect of "now superseded by part no: **************** and we would update the number in our spares department card ordering system and manuals if there wasn't already an update sheet for them.
Lawrence.
ms660 is offline
Old 2nd Mar 2021, 10:34 pm   #7
Mrrnoname
Hi all,
Thanks for this, I will continue the search. Interesting regarding the different variations of the motor pulley.
Regards,
Max.
Old 2nd Mar 2021, 11:12 pm   #8
DMcMahon
DMcMahon's Avatar
I can now see the "Table Ass'y, motor pulley holding X-3472-029-0" in the 377 manual, it shows it sitting directly on top of the motor.
DMcMahon is offline
Old 2nd Mar 2021, 11:28 pm   #9
DMcMahon
DMcMahon's Avatar
Max for a small fee I could sell you the motor pulley (50Hz / 0 standard speed version) mounted to its holder (with securing grub screws) and the relevant idler wheel that drives the flywheel (just removed from one of my TC-399's).
I will send you a PM.
ID:	228126   Click image for larger version
ID:	228127   Click image for larger version
DMcMahon is offline
Old 3rd Mar 2021, 12:03 am   #10
DMcMahon
DMcMahon's Avatar
Lawrence.
Found a complete 377 Service manual (the AEP/USA only Models version) where the Speed adjustment procedure is on page 15. It is very good quality with some coloured drawings and good photos.
DMcMahon is offline
Old 3rd Mar 2021, 11:19 am   #11
ms660
ms660's Avatar
The missing pages are on here anyways:
https://www.vintage-radio.net/forum/...ad.php?t=74712
The speed adjustment procedure is the same for all the models that's been mentioned, all use Sony test tape SPC-47 for the reference frequency.
Lawrence.
ms660 is offline
Old 3rd Mar 2021, 2:22 pm   #12
DMcMahon
DMcMahon's Avatar
Thought I had originally downloaded it from sportsbil.com (see that manuals no longer appear to be downloadable from this site) but now realise it came from hifiengine.com
Have emailed the full Service manual to Max.
DMcMahon is offline
Old 3rd Mar 2021, 2:30 pm   #13
ms660
ms660's Avatar
Sportsbil has only recently gone down, I checked the Sony TC-377 manual on there the other day, same pages missing, hope that site comes back, was good for Tandberg stuff.
Lawrence.
ms660 is offline
Old 3rd Mar 2021, 5:43 pm   #14
Mrrnoname
Thanks David, got the manual. It's significantly better than the copy I had previously so I really appreciate it.
Excited to receive the parts in the post. I've been looking for them for what seems like an age.
Max.
Old 10th Mar 2021, 9:23 am   #15
Linnovice
Originally Posted by Mrrnoname View Post
Hi All,
Motor Pulley
Regards,
Max.
Hi Max, I have a complete machine in pieces I’d be willing to part with. I started to dismantle with the intention of refurbishing but a few Revoxs got in the way . It all worked fine but, in truth, was a bit smelly. It had spent most of its life playing background music in an Indian restaraunt!
PM me, I’m sure we can come to an arrangement.
Mike
Small Scotch, New Aids and Happy Ears
Linnovice is offline
Old 10th May 2021, 6:27 pm   #16
hape001
hape001's Avatar
Originally Posted by Linnovice View Post
Hi Max, I have a complete machine in pieces I’d be willing to part with. I started to dismantle with the intention of refurbishing but a few Revoxs got in the way . It all worked fine but, in truth, was a bit smelly. It had spent most of its life playing background music in an Indian restaurant!
Mike
Are you willing to sell more parts from that deck? I've got a TC-366 that's missing a few parts.
BR/
Peter
hape001 is offline
