24th Oct 2012, 9:59 am | #1 |
R1155/T1154 Racal Oscillator 9417
In a box of R1155 parts I have found a Racal oscillator, looks like a plug in unit for the T1154 transmitter, taking the place of a valve, with a British 5-pin base.
Does anyone have any further information on this unit, I would like to use it if possible. What has happened to GV4CU who supplied spares for these radios? Anyone taken over from him? |
24th Oct 2012, 12:31 pm | #2 |
Re: R1155/T1154 Racal Oscillator 9417
Any chance of a piccy? Sounds like an interesting bit of rework by someone given that Racal didn't even exist when the T1154 was in production.
G4CVU might be a more useful search term..... but this thread may be more helpful still: https://www.vintage-radio.net/forum/...ad.php?t=82463
....__________ ....|____||__|__\_____ .=.| _---\__|__|_---_|. .........O..Chris....O Last edited by Herald1360; 24th Oct 2012 at 12:40 pm. |
24th Oct 2012, 5:19 pm | #3 |
I have a Racal "Frequency Standard 9420" which is a square section grey box with a 7 pin plug built into the bottom, looks like a valve base plug. Mine is a 5 MHz unit and they are an ovened crystal oscillator used in lots of Racal kit of around the 70s/80s. I believe they were also an optional part in some things which did not have ovens in their basic form, and were no doubt available in different frequencies.
Gordon |
24th Oct 2012, 5:39 pm | #4 |
Some photos of the unit
24th Oct 2012, 8:38 pm | #5 |
I don't think you'd get that in a 54, so guessing its for some other bit of kit.
Ben. |
24th Oct 2012, 10:49 pm | #6 |
That's an enormous crystal- looks like it could be a 100kc/s refrence of some sort.
"Racal Electronics" was one of the older iterations of the Racal radio business which probably dates the unit to the '50s sometime. The 10V reference suggests a military application, I think.
26th Nov 2012, 3:56 pm | #7 |
Re: T1154/Racal Osc. 9417
This item was made for use in T1154, which were used in the 1960's for fixed ground use, ie remote weather beacons etc. It is a direct replacement for the osc.valve. |
27th Nov 2012, 12:22 am | #8 |
That sounds like experience speaking!
Another interesting snippet to add to the mountain of arcane information buried in here. Do you know what frequency the unit generated?
