Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Reply
Old 10th Jun 2021, 4:57 pm   #1
FIXITNOW
FIXITNOW's Avatar
Default Wanted class 2 probe or connector for Metrotest Mpat
wanted class 2 probe or connector for Metrotest Mpat40
picked this up checked out ok for class 1
but the probe for flash test class 2 is missing
anyone got one for sale
or can ID the connector used
as have some HT cable and Tufnell bar so could make some thing up
cheers
picture if it helps
FIXITNOW is offline   Reply With Quote
Old 11th Jun 2021, 12:55 pm   #2
Alistair D
Alistair D's Avatar
Default Re: wanted class 2 probe or connector for Metrotest Mpat
I have an MPAT60 with exactly the same Hirschmann connector. Hirschmann have no recollection of this part and were quite surprised to see the photographs I sent. Unless a second hand one turns up it looks like its a DIY job.
Attached is a copy of the MPAT40-60 user instructions. There is a line drawing and a little more info on the plug in the flash section.
Al
Alistair D is online now   Reply With Quote
Old 11th Jun 2021, 1:44 pm   #3
FIXITNOW
FIXITNOW's Avatar
Thank for the info and user guide
was thinking swap out for a 4mm shrouded socket but these only seem to be up-to 1KV
Old 20th Jul 2021, 6:00 am   #4
FIXITNOW
FIXITNOW's Avatar
on my usual car boot hunt i found a guy that had cleared an electronics company so had a carrier bag of diodes, fets, transistor's, 1/w resistors ,caps and test leads also this Clair flash probe ; which had already had its lead cut down and 4mm socket fitted so made an extension lead. found a 4mm socket that once removed from its sleeving would fit into the socket on my tester
so made this up the test lead is rated at 3KV if untouched so may need to make up another with a bit more chunky spec silicone wire but it works for now
ID:	237988   Click image for larger version
Reply
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
