Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Reply
Old 8th Jun 2021, 5:59 pm   #1
Wonkbud
Default Need help finding info on a Dux radio model.
Anybody here who knows where I can find info on my great grandfather's dux battery radio? It says it's a
type B 22.
Wonkbud is offline   Reply With Quote
Old 8th Jun 2021, 6:58 pm   #2
AC/HL
AC/HL's Avatar
Default Re: Need help finding info on a Dux radio model.
A photo may help, there could be a Philips version.
Bill, BVWS member
AC/HL is offline   Reply With Quote
Old 9th Jun 2021, 12:07 am   #3
Wonkbud
OK! So if this works there should be a link to a picture of the radio above!
Old 9th Jun 2021, 4:04 pm   #4
Wonkbud
Default Dux type B 22. Need help finding what type of voltage is needed.
So i have a Dux type B 22 battery powered radio from 1938 and I need to know what voltage the batteries should have does anybody know?
Old 9th Jun 2021, 4:12 pm   #5
Cobaltblue
Cobaltblue's Avatar
Default Re: Need help finding what type of voltage is needed
Any chance of telling us the Valve line up?
In light of no internal pictures and to date no sign of the Dux service data we at least need to know what type of valves it uses for anyone to help.
Mike T
Don't care if it was a bargain why's it in my kitchen
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now   Reply With Quote
Old 9th Jun 2021, 4:13 pm   #6
vinrads
The type of valves will tell you, I would think 1938 valves would be 2 volt heaters and 120 volt HT poss grid bias battery. Mick.
vinrads is online now   Reply With Quote
Old 9th Jun 2021, 6:04 pm   #7
Wonkbud
The valve's are KB2 (325 on the backside), a KFU, KCU1 and lastly a kL4 all tubes are Philips Click image for larger version
Its a kb2, KFC, KF4, KL4. All tubes are made by philips and i can provide a picture if need be
The valve line up is kb2, kf4, kch1, kl4
Old 10th Jun 2021, 11:13 am   #8
Station X
Station X's Avatar
KB2 2 Volt heater.
KFC. No info.
KF4 2 Volt heater.
KL4 2 Volt heater.
KCU1 No info.
KFU No info.
KCH1 2 Volt heater.
As for HT I don't know of any HT batteries rated in excess of 120V, but I'm sure someone will correct me if necessary.
The set may also need grid bias supplies. What battery connectors does it have?
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is online now   Reply With Quote
Old 10th Jun 2021, 2:48 pm   #9
Paul_RK
Paul_RK's Avatar
There were a few, I'm not sure any were ever very common here but they were available. This page lists some of them, 126, 135, even 166.5V, and each of those included a few extra cells for grid bias.
http://www.blaukatz.com/tables/ht-and-grid-bias/
Paul
Paul_RK is online now   Reply With Quote
Old 10th Jun 2021, 10:58 pm   #10
Trifocaltrev
Trifocaltrev's Avatar
Hi, All of the Philips/Mullard K series valves are 2 volt heaters. In thye Mullard nomenculture A = 4v, E = 6.3V, K - 2v & D = 1.4v
Regards
Trevor.
Trifocaltrev is offline   Reply With Quote
Old 10th Jun 2021, 11:23 pm   #11
Trifocaltrev
According to the Radiomuseum, the KL5 replaced the KL4, I am wondering if the set is a clone of the Philips 631B and it has had a KL4 fitted at sometime in it's life?
Regards
Trevor. https://www.radiomuseum.org/r/philips_631b.html
Old 11th Jun 2021, 4:39 pm   #12
Wonkbud
I don't know given that not even that not even my grandfather knows anything about it. Though i could check if given instructions on were to look.
Old 29th Jun 2021, 11:31 am   #13
Wonkbud
Okay so if all the tubes are 2 volt heaters as per the k model series. Then what amount of voltage would that amount to? If the radio has 4 valves?
Old 29th Jun 2021, 10:00 pm   #14
Herald1360
Herald1360's Avatar
2 volts if they're in parallel (they normally were).
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is online now   Reply With Quote
Reply
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
