19th Feb 2021, 5:26 pm | #1 |
Standard Telephones & Cables, STC R6
Hi
The Radio Museum has been sent photos of an STC R6 receiver. Going by the wavebands it looks like it is possibly an early Navy receiver from around 1935. The frequency ranges are; 1200 - 430kHz, 430 - 158kHz, 158 - 60kHz It has 8 valves 9D2 9D2 9D2 9D2 9D2 9D2 11D3 7D7 here are some photos. Any comments on its use, history or other information would be very helpful. Thanks Mike |
19th Feb 2021, 5:35 pm | #2 |
Re: Standard Telephones & Cables, STC R6
Nice.
Lawrence. |
19th Feb 2021, 5:46 pm | #3 |
The 2 big tuning-drives look identical to those used on the Gee "RF" units of WWII-vintage.
19th Feb 2021, 6:08 pm | #4 |
21st Feb 2021, 7:48 pm | #5 |
The two big tuning drive are quite standard slow motion drives by Muirhead. Nice to see the bakelite outers aren't broken.
Common in late thirties and WWII stuff. David
22nd Feb 2021, 11:04 am | #6 |
The architecture is remarkably similar to the ST&C WWII-vintage BBC CS-8 100kW broadcast transmitter drive units, as shown here at OSE9, even down to the colour of the paint (yes, I know it's black and white...).
Regds, Russell W. B. G4YLI. |
25th Feb 2021, 9:52 am | #7 |
We have found an entry in the Wireless for the Warrior compendium 3 foreign data sheets, with a little more information.
Commercial or Naval receiver Frequency Ranges; 1200 - 430kHz, 430 - 158kHz, 158 - 60kHz Receiver: Type R6 Commercial or Naval receiver Circuit: Superhet, with BFO for A 1 Valves: 6 x D2, 1 x 7D7, 1 x 11D3 Power source: accumulator 12 V, anode battery 160 V or power supply unit (see type R 5) Antenna: Ordinary single wire antenna. Size: Receiver: 760 x 330 x 330 mm Power supply unit: 305 x 230 x 150 mm Weight: Receiver: 37 kg Power supply unit: 12 kg Usage: Fixed and mobile radio stations, also air force or navy. Make (manufacturer): Standard Telephones and Cables Ltd, London. Remarks: Fading compensation (AGC), bandwidth control, Tone Filters (tone control) and noise limiter available. Can also be used as a direction finder with auxiliary equipment. Not confirmed as an army device. |
