Old 12th Apr 2017, 9:40 pm   #1
1955APREN
1955APREN's Avatar
Default AOR AR2700 Fuse?
I have a AOR AR2700 that as gone dead need help in identifying this part(i think It might be a fuse) It as some very hard to read small numbers on it. I think I have read 4.19. If this is a fuse does any one know what value is it?
Please see enclosed photo. Thanks for any information regards, Derrick.
1955APREN is offline
Old 12th Apr 2017, 10:16 pm   #2
Martin G7MRV
Default Re: AOR AR2700 Fuse?
certainly a fuse, but couldnt say the value
I got food in ma belly and a license for ma telly
My Blog - http://g7mrv.blogspot.com
Martin G7MRV is offline
Old 12th Apr 2017, 10:19 pm   #3
McMurdo
McMurdo's Avatar
I'd suggest it's a Murata CSA-C series ceramic resonator.
Kevin
McMurdo is offline
Old 12th Apr 2017, 11:10 pm   #4
SiriusHardware
In which case probably 4.192Mhz, commonly used in digital circuits for generating the clocks for tone encoding and decoding circuits and other timebases. We use a DTMF decoder IC which uses a 4.192Mhz crystal.
Certainly 4.19A would be an unrealistically high value fuse to find inside a handheld radio scanner.
1955APREN, does this item have a part number (ie, FS1 or X1), screenprinted on the PCB beside it?
SiriusHardware is offline
Old 13th Apr 2017, 6:36 pm   #5
Martin G7MRV
Sorry, that should have said "certainly looks like a fuse!
We used very similar looking ones in the Kenwood PMR handhelds I serviced for the Home Office, rated 3A.
As SH suggests, knowing what the silkscreen says in the position it came from in the radio could be decisive
Old 15th Apr 2017, 7:10 am   #6
1955APREN
1955APREN's Avatar
Thank you all for advice. The PCB does not have any markings on it at all. If it is a fuse then it's OC. I connected it to my component tester and it reads 44pf (a capacitor). It seems that it is a resonator. I will refit it ASAP and look for further faults. Sorry that I did not get back before, had busy week.
Thanks again, Derrick.
